Thread: 2.0 dti fault codes help
    Apr 2009
    stockton-on-tees
    Default 2.0 dti fault codes help
    could anyone give me advice on how to fix this fault please the car is running slow and lumpy it is also hard to start after being left for a period of time been told it could also be the pump timing is out P0400 Exhaust Gas Recirculation Flow Malfunction
    P0380 Glow Plug/Heater Circuit Malfunction i think its is the cause of the starting problems im going to go and buy a new relay to see if this works any other suggestions please cheers baz
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    i have a 2.0L DTI and had P0400, it was the EGR valave at fault. as for the other fault code i dont no. HTH.
    Apr 2009
    stockton-on-tees
    cheers mick what did you do to fix the fault? ive got a new glow plug relay and leak off pipes was going to clean the egr valve too cheers
    West
    check all the vac pipes etc... the rubber connecting ends split throwing the same fault code.
    Also check each glow plug to see if it's heating up, although the pre heating system is not used in temps above 5*
    hth
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    i cleaned mine and it only lasted 200-250mile before it gave up completely. i got the EGR valve from ebay for £215. fault sorted after that.
    but,
    i would do all the pipes first, replace all the rubber connectors and t-pieces, if that doesnt fix it then EGR or acctuators are goosed.
    acctuators are the bits the pipes connect to, check these have a vacume by wetting your finger and placing it on the acctuator vacume output (its labeled on the top) while the engine is running. you should be able to detect a vacume with a wet finger, i thort i couldnt so replaced the acctuator and still could only detect a tiny vacume so left it like that.
    any questions just ask.
    mick.
    Apr 2009
    stockton-on-tees
    alright ive still got a p 0380 fault code after replacing the glow plug relay with a new 1 but the p0400 fault code has now gone is there anything else i could try apart from the glow plugs themselves cheers for all your help
    Apr 2009
    stockton-on-tees
    also i wiped the fault codes after fitting the relay cheers
    Apr 2009
    stockton-on-tees
    bump
    Apr 2009
    stockton-on-tees
    bump
    Apr 2009
    stockton-on-tees
    alright still having problems with my vectra i have changed glow plug relay and glow plugs but i am still getting p0380 high voltage fault can any1 help me please. i also changed leak off pipes, t peices and cleaned the egr valve which made the first start of the day very difficult so i put the old leak off pipes back on and this brought it back to normal any help is much appreciated cheers
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
