Thread: Anyone know what this means, or dare to try it.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Default Anyone know what this means, or dare to try it.
    Just looking on the TIS and found this field remedy, does anyone know what the solution actually does (highlighted in bold), i'm curious now and want to go out and try it, but don't want to knackering anything up!
    Field Remedy: 1470
    Subject: Central locking - Malfunction
    Models: Engines: Option:
    Vectra-C 2002... All Central locking
    Complaint: Functions of the central locking system incorrect
    Cause: Transport modus is switched on
    Production:
    Remedy:
    At pre-delivery inspection and in cases of complaints with central locking
    system, it is necessary to deactivate the transport mode (hold both steering
    stalk switches in upper position for at least 3s when ignition lock is
    switched-on in position "I").
    For more details please see technical innovations Vectra C (TIS 2000).
    FunctionalGroup: N - Electrical Equipment
    Complaint Group: 04 - Electrical failures,13 - No/Poor Function
    Trouble Code: None
    To me, it's pretty much what it says. When the cars are being transported the Central Locking is put into 'Transportation Mode' (possibly the CL system switched off).
    Before the car is sold, at PDI, it has to be turned off by the method described.
    Whether it will turn the 'Transport Mode' back on again if you did that procedure now, I don't know, but you can try and let us know what happens!!
    Feb 2006
    Guttedsville
    Go on Duncan, You've got a hire car at the mo!
    Mileage : 000
    Yes Duncan, Lets have a how to, in messing up the central locking on a hire car.
    PRESTON
    Trim : GSI
    i daren't try it, do you think worst case it may disable the central locking system. Perhaps when the cars come from the factory you have to open the door with the key, and only the drivers door unlocks. who knows.
    Regular Member cpt slow's Avatar
    In a house
    When I worked at a Peugeot main dealer , ALL the cars that came in to the dealership straight off the transporter had their Central locking locked if that makes sense . It was the PDI technician that enabled it in the workshop . Maybe Vaux. are the same ?
    Quote Originally Posted by Andrew's SRi
    Quote Originally Posted by ed taylor
    Oh yeah, now there's an idea!!
    Just doing an oil/filter change on Mrs Duncan's Corsa. I'll have a play with the hire car a bit later!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Just triedit on mine. nothing happened.
    Kent, UK
    Perhaps if up disables, down might enable?
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Is this not something that is used to transport the cars when leaving the factory on car transporters but then the option is removed or should be by tech2 on PDI.
  1. Do i dare buy another one?
    By danman487 in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 23:43
  2. Low... as far as I dare....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 20:32
  3. How VERY dare they !
    By FIL 4822 in forum The 'Off Topic' room
    Last Post: 30th July 2010, 07:12
  4. I dare you!
    By AJA in forum Comedy & Humour
    Last Post: 12th July 2007, 09:56
  5. How low do you dare go?
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2006, 13:41
