Results 1 to 2 of 2
Thread: my center vent is broken
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default my center vent is broken
    as above one of the center vents wont close anymore, It will move up and down but not close. Is it easy to fix or will I need a new one?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The centre vent assmbly isn't too hard to remove, so I would be tempted to remove it and investigate the problem before deciding on finding a replacement.
    Carefully prise off the trim strip below the vents (one item right the way to the passenger door - spring clips every 100mm or so).
    With the trim removed, undo the four bolts securing the vent assembly - two below each vent.
    You can now carefully lift the vent assembly forward. The screen unit comes with it. Once far enough out, you can lift the locks and pull out multiplugs as required.
    Should it be needed, the screen can be removed from the vent assembly by removing the four screws, one in each corner at the back of the screen unit.
  1. Broken air vent
    By Lao in forum Bodywork & Interior
    Last Post: 4th May 2010, 21:20
  2. Air vent broken
    By norfolk in forum Bodywork & Interior
    Last Post: 20th January 2010, 14:23
  3. center vent outlet
    By jcc34 in forum Bodywork & Interior
    Last Post: 6th October 2007, 08:00
  4. Dash air vent broken....help!
    By TonyR999 in forum Styling
    Last Post: 16th November 2006, 22:59
vectra c center vents removal
