Results 1 to 10 of 16
Thread: Is the 1.8 VVT Engine a solid reliable engine ?
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default Is the 1.8 VVT Engine a solid reliable engine ?
    I've been asked if the 1.8 VVT engine that they use in the Insignia has any inherent issue's with it. Does it have any known problems. ??
    Think its more or less the 1.8 that was used in the later vecs.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    If it is the same I would have said its pretty solid
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    well the vectra engine is a very good lump.
    Apr 2008
    In UK
    Cheers guys..
    Yes it does to be a reliable unit, I spotted the Engine Reliability Poll after I posted this and it seems no-ones had any problems at all with it.
    Looks like most of the issues reported are with diesels..
    Regular Member Robbie69's Avatar
    Touch wood, never had a problem with mine but now i've said that!!!!!
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    I used to say it was as reliable as anything, untill last week when my VVT system failed and flooded the valves with oil, slipping the timing whilst it was at it, 2006 plate Sri with 43k on the clock, always serviced on time, mechanic says its just one of those things
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    So far so good mate.
    Leicester
    Quote Originally Posted by Cameron43 View Post
    The block is the same as Vectra/Signum Astra etc, but the head has been slightly modified to suit the Insignia's Euro 5 requirments.
    I wonder if the head modifications are also in preparation for the rumoured 200PS turbo version.
    Regular Member videodoctor's Avatar
    Blackpool
    I've had to have a new clutch and flywheel fitted to my 1.8 vvti vectra at only 2500 miles.It still judders ocasionally even after fittting the replacement.Also had a stuck thermostat at 9000 miles.So for me its not be totally reliable.
    I also find it annoying when changing gear from 1 st to second because of jerky gear change.Also i don't think the vvti is as quiet as the previous 1.8.
    If i was going to buy an Insignia i would avoid the 1.8 and go for the 2 litre.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    The only fly(wheel!) in the ointment is the clutch judder which is a known problem and apparently requires flywheel replacement (if I read it right).
    If it is as good as the old 1.8, it will not disappoint. I had one of the older 1.8's in my 53-plate Vectra, and I had no issues whatsoever in 2 years of ownership from new.
  1. In your opinion what is the most reliable Vectra C engine
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2012, 00:24
  2. does the dti engine have a DMF or solid
    By peadar in forum Engine & Drivetrain
    Last Post: 17th December 2011, 22:21
  3. Is the vauxhall 2.0 turbo engine reliable???
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 9th February 2011, 22:09
  4. Most reliable diesel engine?
    By SD1992 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 00:42
  5. How reliable is the 2.8T v6 engine
    By jlb777 in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2008, 09:36
1.8 vvt engine reliability
1.8vvt engine
vauxhall insignia 1.8 vvt engine
