Thread: Air con not working
    Regular Member pauls898's Avatar
    Malvern
    Default Air con not working
    (Sorry for posting here system won't let me post this under aircon as locked)
    Put my air con on for the first time for a while, no change in temperature at all, pipes in engine bay were not cold at all I suppect the coolent has leaked out?
    As recommended I took it along to kwickfit for a recharge.
    They connected it to a machine which vaced the system for 30 mins to remove whats left of old stuff, did a leak test and re-filled the system.
    Seems to have fixed the problem as blowing cold air once more
    However does anyone know what colour this aircon coolet is? Because I have noticed a yellowish liquid in a patch on the aircon radiator????
    Now this is either leaking out, if its yellow?, or the garage has spilt some brake fluid on there which I hadn't noticed??
    Air seems ok at the moment but the front of the aircon rad does look in a doggy state from road grit and dead flies etc.
    Later after a week of use the aircon is hardly working again I recon there is a leak in the rad, theres a big damp stain in middle of rad and only the top left corner was getting warm ???
    So guys, whats the damage for a replacement air con rad? Looks as if a stone has punchered it and it will have to go into Vauxhall after all
    You should use the a/c at least 20mins per month to keep the system from drying out and the coolant leaking out (its in the manual). They yellow liquid could be the dye from what they have added to the gas.
    It could mean a new rad if its got a hole
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    at vauxhall thry regas it and put a dye in as well that cost u 99 quid take it back after a week they re check looking for any dye seepage if there is a leak part covered by warranty and u get ur 99 quid back...thats if car under warranty...
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Budget around the £110 for a generic replacement condenser, add postage + VAT.
    Not a difficult job to do assuming you have things such as tork sockets and a Haynes book - I recently did an Omega one on my drive in 3 hrs. Do the job yourself then off back to Kwikfit for test and refill. Can't quote for the average Vx Main Stealer, but I'm guessing you can do it yourself one hell of a lot cheaper.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
vectra air con not working
