Results 1 to 10 of 15
Thread: Coolent Change
    Aberdeen
    Default Coolent Change
    Folks,
    Going to be serviceing the car this weeknd. Oil/Filters/Wiper blades. But looking at the service plan, a coolent change is listed.
    Is this just a matter of undoing a rubber hose on the lowermost part of the raidator and draining the coolent?,Reconnect the hose and fill with water mixed with anti freeze?
    Any advice?
    TheWildHaggis
    Pretty much yes. Just make sure you get the orange longlift stuff as the pink one can corrode the ally in the new blocks aparently. Also the two don't mix and can foam a bit
    Wales
    Im pretty sure the longlife stuff I bought from vx recently is pink???
    Quote Originally Posted by snapsnap View Post
    As long as its not blue what does it matter?
    WGAF#5
    Exclamation dont forget
    and you will have to bleed the air out of the system as well
    otherwise you may get airlock and you could have insufficient fluid in the system .....and then you could have some problems
    Wales
    ...the pink one can corrode the ally in the new blocks aparently....
    Aberdeen
    Errmm....
    How do I bleed the system?
    I thought that was just for doing the brakes
    WGAF#5
    Quote Originally Posted by TheWildHaggis View Post
    Errmm....
    Fill the system by slowly pouring the coolant into expansion tank until it is up to filler neck.
    Using a small screwdriver ,lift up the wire clip securing the left hand heater hose to the heater matrix pipe stub,and disconect the hose from the stub.
    Additionally,on 1.9 ltr engines,open the bleed screw in the coolant pipe above the exhaust manifold.
    As soon as coolant begines to run from the heater matrix,push the sucuring wire clip back into position on the heater hose end fitting ,then push the hose back onto the matrix pipe stub.
    Ensure that the wire clip securly locks the hose in position.
    close the coolant pipe bleed screw as soon as coolant emerges.
    hope this helps
    regards
    Dez
    Aberdeen
    Many thanks
    WGAF#5
    Many thanks
    thank the man in the haynes manual
  1. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  2. Cracked coolent pipe
    By jmd5757 in forum Engine & Drivetrain
    Last Post: 14th February 2011, 10:39
  3. Coolent change
    By amir2300 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 22:16
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
  5. coolent temp 1.9 CDTi
    By POAH in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2006, 23:04
