Results 1 to 10 of 16
Thread: What's wrong with my Vectra??
    Regular Member zazaszazas's Avatar
    Cumbria
    Default What's wrong with my Vectra??
    Have a problem with my Vectra.Ok here is my story..Bought the car 3months ago and while i was driving it over bumps i've had a knocking noise from the back and the front of the car.Also when i'm driving it over bumps there is a sort of shaking coming from the back of the car.Recently changed springs(Konis all around),front anti roll bar links and the rear control arms.There is still knocking noise and the shaking What to do next?? Btw I've got Gt Champiro tyres fitted(cost £80 each)
    Northampton, UK
    Have you checked the simple things like the radiator mounts?
    When I took my front bumper off for the first time, I noticed that the steering fluid bottle was loosely held on as the mounting cage had been damaged at somepoint, so that was bumping around over bumps ( I was lucky to notice that!).
    Then I had trouble with the rubber airbox mounts, that was bouncing around everywhere.
    Then I noticed that the front bumper didnt have any plastic push rivets holding it to the underneath of the car, so that was slapping around...
    With the back, I'd check your exhaust mounts as a starter for the knocking noise...
    Cumbria
    Quote Originally Posted by n_hudson View Post
    Thanks for the advice.I'll have a look over the weekend..the front sounds like some sort of metal knocking..I was thinking the steering rack or driveshaft or might be the shock absorbers?? but still why is the rear end shaking when i drive thru bumps??Sure its something to do with the suspension isn't?
    Regular Member mishima's Avatar
    UK
    I have exactly the same problem. I have replaced upper control arms and ARB bushes. Still there. It's very annoying, if you discover what is wrong wit yours please post up!
    Cumbria
    Quote Originally Posted by mishima View Post
    will do m8..well i'm going to change my shock absorbers for Koni ones and i'll see if that will make any difference
    Sunny Dartmoor
    Have you changed your drop links?
    They're about £20 for the pair and can give you a knocking noise,worth a try m8.........
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Glenboy is spot on here... it cured my problem after the knocking was still there after getting the rear control arms replaced.
    Cumbria
    Quote Originally Posted by glenboy View Post
    as i said i've changed the drop links(anti roll bar links)and the knocking noise still there
    UK
    Same for me, replaced all those parts and still that nasty noise. Watching this thread closely!
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    go for a drive and let some one else drive while your in the back and fold the back seats down and see if you can hear it to give you a better clue
  1. Brought used vectra Sri 1.9cdti 2006 what could be wrong???
    By King of Lead in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 22:43
  2. Vectra C 1.9CDTi SRi - wrong wheels?
    By Tigerrider in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2010, 18:40
  3. The Vectra has all gone wrong in the sun
    By tramman in forum Vectra C / Signum Troubleshooting
    Last Post: 24th May 2010, 22:35
  4. What else can go wrong with my Vectra?
    By BRYBURN in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 21:43
