Thread: Misfire survey
    preston
    Default Misfire survey
    I'm pretty convinced now that we really haven't found the cause of the mysterious misfire on 1.9 cdti engines (120). It seems that changing injectors,glow plugs,injector plugs and EGR valves has no effect and i wouldn't recommend changing these in an attempt to cure the fault. My glow plugs have been changed, egr cleaned and checked, injector wiring (all 4) changed and still misfires at 2900 rpm in 2nd and 3rd moreso when engine very hot after being stood in traffic for a while. Its almost like a momentary shut down of engine than misfire and no warning light is displayed.
    I'm trying to get to the bottom of it and wondered is it just my car or is it more widespread fault? you're response would be welcomed
    May 2006
    scotland
    There was a chap on here yesterday that had dodgy water temp sensor wiring that was causing limp mode but i guess if its intermiitently faulty it may case a missfire symptom. Long shot but just a thought. Maybe worth checking.
    Regular Member Kyser143's Avatar
    Bradford
    you tried the coil pack...mine had a misfire and that was the problem. no warning light until a few months down the line.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, defo the coil pack that is at fault on your diesel.
    preston
    Well if it did have a coil pack I would change it
  1. Immigration Survey
    By John Bishop in forum Comedy & Humour
    Last Post: 16th October 2012, 09:23
  2. Spoons 2010 Survey 1
    By spoons in forum General Chat
    Last Post: 30th December 2010, 09:39
  3. Quick Survey
    By corsa_si in forum The 'Off Topic' room
    Last Post: 10th May 2009, 13:46
  4. Vectra C reliability survey
    By Krzysieq in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 16:52
  5. Top Gear survey
    By big phil in forum General Chat
    Last Post: 13th November 2005, 23:56
