Thread: lights on dash and other probs
    TENBY/BELFAST
    Default lights on dash and other probs
    Hi guys been a while since iv been on here,was driving about an hour ago and the light that looks like a spanner with a car behind it came on,car shuddered then battery light came on ,so i turned it off and started the car again and it went away and i continued driving then it came on again then the battery light.......then temperature light came on and temperature was in the red,pulled over ant opened bonnet and coolant is now leaking but its not low on level.each time i drive for 5 mins the spanner light comes on the the battery light and temperature goes mad.
    all help welcome......2004 signum 2.2dti elegance
    May 2006
    scotland
    Leaking water from where? It could be the cylinder head gasket leaking or the water pump.
    TENBY/BELFAST
    No the leak appears to be coming from the bottom of the coolant resovoir,were can i find the drive belt in the engine to check it any one got a pic of were to look.
    2.2dti doesn't have a cam belt its a chain so I will assume the aux belt drives the water pump?
    TENBY/BELFAST
    Well i went and had a look myself and its the belt but it doesnt seem to have snapped,so whats the damage im looking at and what sort of costs.Is it still safe to drive to the garage.
    May 2006
    scotland
    This sounds as if this belt is supposed to be driving the water pump (when on correctly)so it will overheat if not driving the water pump. If you are more than 5 minutes drive from the garage, it will start to overheat again on the way there. Overheating is not good for longevity of the engine. If you are a member of the AA or RAC call them out if you have that cover. Other thing you can do is take out the thermostat and the cars water would take longer to boil up thus enabling you a greater distance to drive and have it fixed.
  1. Dash lights
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 21:51
  2. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  3. No Dash Lights
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 07:26
  4. Audi style led lights probs
    By the_wave_rider in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2010, 12:21
  5. Dash lights?
    By Messenger in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 21:29
