Thread: 3.2 V6 Fault - Help Appreciated
    Regular Member pjjohnst's Avatar
    Shetland Isles
    Default 3.2 V6 Fault - Help Appreciated
    Hey folks, i have a 3.2 V6 Gsi, and the spanner light came on this morning.. Anyway, it dissapeared after 5 seconds, but re-appears everytime i turn the ignition on - can anyone help?
    I remeber reading a thread on here that the V6s had some method of self diagnosis, so i can figure out the fault code, but i have spent ages searching, without prevail..
    If anyone can help it would be greatly appreciated. The car is not underperforming, nor is it making any noises.
    Peter
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    If it goes out when the engine is started then I don't think you have a problem. Mine seems to do this straight after it has been serviced but stops after approx 2-3 weeks.
    Regular Member Bloicy 3.2 V6 GSI's Avatar
    Aberdeen
    Mine does the same. Although i think if you put you keys in the ignition without turning them, then put your foot on the brake pedal and at the same time press the reset button for the milometer and turn the ignition key to stage 1 it should reset. HTH
    Quote Originally Posted by Bloicy 3.2 V6 GSI View Post
    Where did you read that? That sounds like its for the service indicator not a fault light.
    If the spanner comes on and goes out it means its seen a fault but its no longer present. It should go after 30 or so starts of the engine or if you wish you can remove the battery for 30 mins or so to reset it yourself. make sure you have the stereo code if you do this - assuming you still have the vx HU.
    E Sussex & Kent
    That would tie in with 2-3 weeks then, I wonder if they generate a fault intentionally whilst doing the service to check something?
    Melbourne, Australia
    Quote Originally Posted by pjjohnst View Post
    Stop searching, here it is: How to read engine fault codes on a Z32SE (3.2 V6 petrol)
    Mileage : 000
    Do what I do when there is some good information. Save it in a folder in my documents.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Mine does it now and then but it just goes off.
    It started when I tryed the wrong key
    But its out now and stayed off
    Regular Member hagga's Avatar
    kingswinford
    mine does this on rare occasions too...just as I'm getting used to it..it goes
    Shetland Isles
    Thanks for all the help folks, ill save all the info i can, and post back what the problem was
  1. your help would be most appreciated
    By bigbow in forum Bodywork & Interior
    Last Post: 14th November 2012, 23:41
  2. any help appreciated....................
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 18:10
  3. Anyone used these/advice appreciated
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2010, 16:40
  4. Help appreciated
    By mickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2010, 15:51
