Results 1 to 10 of 11
Thread: Fuel Tank?
    Yorkshire
    Default Fuel Tank?
    I ran my car until the petrol light was flashing. at this stage my range was 1 mile.
    I filled the car up with petrol and it only took 54 litres of fuel off me.
    I thought the cars had a 60 litre tank?
    Surrey
    You can drive for ages on zero as you have found out, as you still had a few litres left.
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    think all vectra s were fitted with 62 litre tanks mate
    Surrey
    61L actually.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by steve1975l View Post
    61L actually.
    ooooo some one has been reading the manual
    llantwit major
    sorry i stand corrected , but could have sworn that my manual says 62 litre, oh well
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Anyway, the point is that even when the gauge shows zero, there is still plenty of reserve fuel left. This is normal
    Surrey
    If you put in more fuel than the capacity of the tank, then you were low.
    llantwit major
    i wouldnt go off the gauge as mine said i had 36 mile left the other day and the mrs took the car to a mates and i said you will get there and back no probs. she got there and parked on a slight hill and when she came out it started then stalled, so off i went got 5 pounds worth of diesel and put it in and it started after a few seconds of crankin it over and this has happened to a few others too
    WGAF#5
    Quote Originally Posted by davidjameswest View Post
    diesels are predomonantly bad for this - on diesels it can also bring on the engine warning light as low fuel makes the car think its got an air leak entry fault on the system
    there was a software update on pre face lifts for signums giving false readings as the tanks were set up as vectras and not signums as well
    hth
    regards
  1. Bad tank of fuel?
    By altitude2k in forum Engine & Drivetrain
    Last Post: 8th December 2009, 14:49
  2. how do i remove fuel tank
    By sandman jim in forum Engine & Drivetrain
    Last Post: 24th May 2009, 09:35
  3. Fuel Tank Capacity
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 00:26
  4. Oil in fuel tank
    By ianh in forum Engine & Drivetrain
    Last Post: 10th January 2008, 22:29
