Thread: Diesel exhausts
    Apr 2009
    Norwich, UK
    Default Diesel exhausts
    I think I once heard that exhaust systems last longer on a diesel car than the equivalent on a petrol one.
    Anyone know if that is true? I believe mention was made that there is less moisture in diesel exhaust.
    Not sure about that one
    Usual cause is external corrosion
    Internal failure is usually due to hot/cold variances, and in diesel engines this is greater
    I can usually get an exhaust to last 4 years / 80K miles
    Regular Member Readster's Avatar
    Plymouth
    Urban myth has it that a diesel exhaust lasts longer due to less water being generated by engine,
    Whether it actually true I wouldn't like to say
    Apr 2009
    Norwich, UK
    Urban myth it is then. As I said, thats what I'd heard.
    Cheers.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's not really to do with water content of exhaust on it's own.
    More to do with the acid compounds produced during the combustion process, eg sulphates, which then reacts with the water vapour and make sulphuric acid which then rots the exhaust from the inside out as well as the normal outside in rust etc.
    Your duty cycle plays a huge role in determining how long the exhaust lasts, a long commute means that the whole exhaust gets hot and doesn't allow the sulphuric acid / water mix to condense and start the acid corrosion mentioned above.
    I'm still on my original exhaust at 110,000 miles and 5 years old, I consider this normal. I didn't replace the exhaust on my last car either (Vec B diesel) which went to 95K before I sold it and the exhaust was still absolutely fine.
    I commute about 70 miles each way to work daily, mainly motorway - which is good for general car sympathy.
    The 'myth' that diesel exhausts last longer may be due to the duty cycle 'normally' associated with diesel cars - ie longer journeys more frequently than their petrol equivalents, which is the main reason why people buy diesels in the first place - ie fuel economy for longer distances to off set higher initial costs and other running costs.
    HTH (I'm a Professional Engineer working in the automotive world, btw)
    Apr 2016
    Telford
    Vehicle : vectra c sri
    Trim : sri
    Engine : 2.2
    Default exhaust question
    Quote Originally Posted by Ste View Post
    hi there i have a 2.2 sri vectra c and i have the chance of a diesel exhaust system but will it be any good on my 2.2 petrol
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Diesel chrome exhausts
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2012, 22:07
  3. Whats the difference in Petrol and Diesel exhausts?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 22:38
  4. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  5. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
