Thread: 2.0 DTi - Rev counter & Warning Lights
    Over the hill and far away...
    Default 2.0 DTi - Rev counter & Warning Lights
    Hi
    I have a little problem that no-one can seem to work out as of yet.
    I have a 2001 dti with 99,000 miles on it. It has been perfect in every way since I got it at 17k (the car only needing some brake work at 50k). I now have a problem that seems to happen mostly on warm days / short journeys once the engine gets up to temperature. The rev counter will fall to 0, and the engine spanner light & water cooling fan light (?) come on simoultaneously. The car doesn't overheat when it does this (still running at usual temps) but the engine sounds harsher than usual & hunts very badly between 0-1000rpm at idle.
    Any ideas?
    I've had the boost sensor & crank sensor mentioned as the cause, but noone has enountered similar.
    When it is running without this happening it is spot on.
    Just unplugged the boost sensor, and it replicated the problem perfectly. Given it a clean & reattached.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Did it fix your problem ?
    Quote Originally Posted by bigmac View Post
    So far, yes. But I haven't been out in the car today. Will have to wait and see if it happens again when the car is warm.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Keep us informed i have the same engine
    Okay, will do. Had a lot of trouble finding any information out about the 2.0dti really.
  1. Rev Counter Lights Flashing
    By cosmic in forum Insignia car chat
    Last Post: 18th December 2012, 16:00
  2. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  3. warning lights on
    By luckyjohn99 in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2009, 20:33
  4. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
  5. Warning Light Under Rev Counter???????
    By sligo_eire in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2008, 19:54
