Results 1 to 10 of 14
Thread: 2.2 dti airbox/filter help req`d
    Feb 2006
    walsall
    Default 2.2 dti airbox/filter help req`d
    hi all,
    i may not be looking in the right place,but i see that by modifying the airbox & filter on my car,i can gain a little performance.....can anyone supply info on exactly what has to be done?
    thanks
    Regular Member Ian's Avatar
    York
    Hi,
    nutron went the whole hog with his:-
    http://www.vectra-c.com/forum/showth...ghlight=filter
    however, you can go as simply as just removing the bottom pipe thats inside the airbox that allows the whole of the filter to be used. This seems to make the major difference.
    Feb 2006
    walsall
    thanks ian..i trhink i`ll try your option first.....he doesn`t mention a filter change....do i fit a k/n filter too?
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I would as it made a load of difference to my mates car.... ..bob
    May 2006
    Northampton
    Default Viper System
    Quote Originally Posted by nev-vec
    hi all,
    thanks
    Hi Mate, I have a 2.2 dti Sri and put a vipor on and it's made a huge differance. I can get you sorted for £110.00 if you want one!
    Pete
    Airbox mod done (de-restricted) and K&N filter fitted on my Vectaru - gave us 17bhp extra - now running @ 140 bhp and 239 lb/ft torque.
    May 2006
    Northampton
    Had mine de-cated with full twin s/s powerflow exhust and full pipercross viper & I re-mapped my car. Standard 150 bhp now Running 196bhp. Not bad for a derv motor.
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I had an x20dth in a prior life and raised that from 100bhp to 138 bhp, the fuel ecconomy also dropped by the same sort of proportion though but I did drive it like a nut.
    That had a drilled air box, k&N panel filter and a lexmaul tuning box. Also tried a K&N cone filter but it cause a drop in low down torque probably because it was too small (K&N have a habit of under estimating diesel engine requirements).
    Nr Cardiff
    I did the K&N and removed the pipe in the airbox today. I could not believe how much cr^p was it the airbox. Dead flies, beed, a lump of polystyrene foam, grass, hay and even two fag buts for Gods sake!
    Doesn't seem tremendously different, but not had the chance of a long run yet.
    Regular Member 111's Avatar
    Stockton-on-Tees
    Mine didn't either
  1. Airbox mod and k&n panel filter!!!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 21:10
  2. will this filter fit in my cdti airbox?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 22:31
