Thread: Squeeky steering
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Default Squeeky steering
    Hi guys,
    Just recently my car has started squeking when i put the car into full lock or a good 90 degree turn (junction), it's the same sort of high pitch noise that you'd get from not enough copper grease on brake pads.
    any help would be appreciated
    AL
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    high pitched squeek when turning wheel sound's to me like the aux belt for power steering is loose...........
    also while your there check the power steering fluid level....
    hth
    Midlands Mod Shop - NFFC.
    May 2008
    Tyneside
    Power steering is electric on the vectra c so no belts. Full lock on power steering puts lots of stress on the system and should be avoided. Lots of threads on forum about lights dimming due to electrical load on power steering pump on full lock - quite normal.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does the noise come from under the bonnet or from the column?
    I have a squeak / squeal but only towards full left lock. Sounds like rubber being stressed..
    Have no idea what it is, but it is defo in the steering column somewhere, one day I'll get some time to investigate....
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    The noise it's self is coming from outside the car, so I'm guessing under the bonnet, I've only herd it while driving too, I'll have a look at the fluid levels shortly
    AL
  1. Squeeky Brakes
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 18:17
  2. Squeeky Brakes
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2010, 18:39
  3. Squeeky Rear suspension
    By hibbsy18 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2009, 01:48
  4. squeeky breaks
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 16:12
  5. squeeky brakes help!!!!!!!!!
    Last Post: 18th April 2006, 00:12
