Thread: Need some help
    Regular Member Mr GTS's Avatar
    Stavanger
    Default Need some help
    Hi everyone, need some help
    After a few minutes of driving, two warning lights appear.
    One of the lights is the TC, but there's no response when I push the tc-button. The other one I'm not sure about.
    Anyone got any ideas what's the problem??
    Engine management light and the tc one. Probably a TC related problem but you will need to get the codes read to find out what. Take the battery off for 30 mins or so to reset them, hopefully they will stay out!
    Blantyre
    Could it be the ABS sensor on one of he hubs, maybe snapped / damaged
    11 Post(s)
    Engine management light !
    Nope, that one is the car/spanner light.
    The one in the picture is the exhaust emmisions light.
    Lights up when the engine is running:
    Fault in emission control system. The permitted emission limits may be exceeded. Consult a workshop. We recommend a Vauxhall Authorised Repairer
    If it flashes when the engine is running:
    For fault that can lead to destruction of the catalytic converter – see page 166. Consult
    a workshop immediately. We recommend that you consult a Vauxhall Authorised Repairer.
    I stand corrected
    Stupid low spec facelift dash!
    11 Post(s)
    I stand corrected
    Bigsig, that was actually quoted from an Aug 2003 Handbook. ie, pre facelift
    Granted though, on earlier Vauxhalls (Cavaliers for example) it was the ECU light.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by spennny View Post
    i had tha ABS light come on when i had high voltage to the sensor, get it code read m8 to see what the problem could be
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i never knew that, as i always thought it was the same, learn something new everyday
