Results 1 to 10 of 24
Thread: Any plumbers ?
    Regular Member Lump's Avatar
    coventry
    Default Any plumbers ?
    how easy are These to fit ?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Hardest part will be drilling through the outside wall from the cut-in stop **** to the garden tap.
    Other than that, IMO, not a bad package.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    give this guy a ring, his name is perry and get a quote, say your a m8 of big rich and he will sort you out...he done mine and its mint
    07853135633
    he supplyed and fitted the lot for cheap as chips
    Blantyre
    I have 2 fitted mate
    cambs
    its easy to fit m8
    a blind monkey can do it
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    would never use one of those kit's in all honesty mate, the tap piece cut's into the copper and the small piece is known for getting lodged in on either an elbow or somewhere else thus restricting the flow of water at another point....
    go to b&q and buy a bib tap a push fit ''tee'' and a short length of copper pipe...easy as pie and a good flow guaranteed....
    hth
    Midlands Mod Shop - NFFC.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Dead easy to fit. All you do is clamp it to your pipe and it cut the hole and seals it all in one. Perfect if you want an outdoor hot water
    coventry
    Quote Originally Posted by gtr1000 View Post
    all in doors,
    Quote Originally Posted by big rich View Post
    07853135633
    unless its cheaper than £12 ?
    Quote Originally Posted by ditchp View Post
    hth
    TBH mate its only feeding a tap in the down stairs loo, so it matters not if it gets a bit blocked ? . the pipe that feeds this goes though the garage. so i can tap into this and have hot water in the garage but this will make me a very happy camper.
    also no smutty comments n thread title ! very disappointed in you lot
    Regular Member mradz's Avatar
    Northants
    personally wouldn't use the kit and would pipe it up properly but couldn't do it cheaper than £12 not a big fan of self cutting taps for long term use. If you do fit it, make sure you know how to turn water off just in case
    coventry
    oh id rather get it done properly, but one T fitting and a tap done by a plumber £50 minimum
  1. Any plumbers in here
    By dannyjpuk in forum General Chat
    Last Post: 26th January 2012, 09:17
  2. Any plumbers on here?
    By lee gsi in forum The 'Off Topic' room
    Last Post: 30th December 2011, 23:18
  3. Plumbers
    By Daywalker in forum General Chat
    Last Post: 21st October 2010, 18:02
  4. any plumbers on here
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 30th September 2009, 22:07
  5. Any Plumbers on here ?
    By markm in forum The 'Off Topic' room
    Last Post: 6th March 2008, 23:27
