Thread: bleed valve?
    Regular Member madman's Avatar
    nottm
    Default bleed valve?
    a mate has said about fitting an in car bleed valve to increase boost on my 2.0 dti. any one fitted one of these and what sort of improvments can i expect?
    cheers
    Regular Member duncan2008's Avatar
    Dewsbury
    as far as i have read on here playing with the dti engine aint advisable as the fuel pumps are very fragile and expensive! i have a dti 2.0 aswell i turned the actuator a few turns and it did make a difference to boost but not alot! im a tech so if mine breaks i can repair myself thats why i took the risk!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i hate bleed valves they cause problems m8
    You should try jet engine bleed valves mate - they're a pain when they stick...
    nottm
    cheers guys. i'll stick with changing the looks of the car then. cant go ******ing owt up that way
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A bleed valve goes in the feed line to the actuator to change the pressure controlling the waste gate. Depending on what model you have it could be effective if done right. Many diesels work on vacuum though and work in the opposite way from that which the bleed valves are intended to work with. In those cases you would reduce performance considerably. Tuning up the fuel pressure at the pump should be possible and adjusting the waste gate to give more would both give you good gains.
    nottm
    so adjusting the wastegate acuator rod and upping fuel pressure is a safe bet ? where is the fuel pump situated and is it easy to increase pressure or replace with an uprated pump? i just want a little more than 100 lame donkeys
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by duncan2008 View Post
    how do you do this??? is it easy and can it be reversed if it doesnt change anything(or a small insignificant change)????
    cheers, mick.
    blackpool
    ok so wheres the actuator
  1. How to Bleed Radiator
    By Sharkman in forum Engine & Drivetrain
    Last Post: 31st July 2012, 11:54
  2. Clutch Bleed
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 19:36
  3. Bleed valve on a 2.0t
    By tomo41 in forum Petrol Engine related
    Last Post: 26th June 2011, 12:50
  4. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
  5. Any one recommend a bleed kit?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 00:33
