Thread: Swirl Flaps Pt 2
    North East
    Default Swirl Flaps Pt 2
    Following on from this thread http://www.vectra-c.com/forum/showthread.php?t=80675
    I have the following results
    Code reader found the following fault codes
    P1109 - Swirl flap positioner 1 faulty
    P1110 - Swirl flap positioner 1 output stage faulty
    The garage has suggested a full inlet manifold replacement with actuator for £624.50 all in.
    Does this sound ok. I do trust the garage and the guys seem to know there stuff.
    Any advice would be greatly appreciated.
    Michael
    Carnoustie
    I'm facing the same problem, sounds about right from what I been reading, mine is driving ok tho, but I guess it well probably with time kill the egr valve, but I think I would give this job a go myself as your bill is probably more than half labour costs
    Ronnie
    Leicester
    £624 is not to bad considering there is about £360 worth of parts. Labour on that basis is not too bad either.
    At least you'll get it all sorted. You could always get them activate the flaps with Tech 2 a few times, this can help to clear it a little and get a few more miles out of it before you have to change it.
    near northwich
    more often than not if the P1109 code is stored the linkage has come off the flaps
    North East
    Car is booked in tomorrow to get the inlet manifold & actuator replaced
    Once this has been done is there anything I can do to try prevent this happening again i.e. the build up of 'crud' etc in the future or is it just inevitable?
    Would putting redex or the like in the fuel every so often help to reduce the problem?
    May 2006
    scotland
    Quote Originally Posted by mpc View Post
    Dont know for sure if it makes any difference but I always use millers or redex at each fill up. Defo less smoke out the back.
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 18:34
  3. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  4. Swirl flaps
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 19:13
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
