Thread: any boiler guys here?
    May 2006
    n.ireland
    Default any boiler guys here?
    Riello 40 burner, Fires for about 20mins then gets to temperature then locks out, I cleaned it out and changed the nozzle and cleaned the electrodes and photocell seems good, Any ideas?
    Regular Member steve0's Avatar
    UK
    Could be a couple of things mate.
    1 - check pump, if the pumps packed in the water in the boiler will heat up rapidly and tell the boiler it is up to temperature and shut down.
    2. Boiler thermostat faulty
    3. Heat exchanger sludged up. Not familier with this particular boiler but if the heating system is fairly old and not regulary maintained it might be the heat exchanger is full of sludge, slowing up water flow and again causing rapid heating rate shuting the boiler down.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Could it be air in the system??
    May 2006
    n.ireland
    Quote Originally Posted by steve0 View Post
    Thanks for the reply mate, It fires up and heats all rads in the house then locks out so the pump and stuff must be fine? or could they still be a factor, When I hit the reset It tries to fire but cant, It sounds like it really struggles to fire then just cuts out. If I let it cool down it fires again. Could it be the control box?
    UK
    From what your saying mate it seems like the boiler is overheating so i would change any overheat stats first as these usually tend to be pretty cheap.
    Also check the fan is working and the condition of the rubber tubes going to it for any holes or damage.
  1. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  2. Boiler specs
    By Ste in forum General Chat
    Last Post: 29th January 2009, 11:07
  3. Duff Boiler.....
    By macdad in forum General Chat
    Last Post: 23rd February 2008, 21:38
  4. Boiler Advice
    By leeds vectra in forum General Chat
    Last Post: 9th February 2007, 00:47
  5. Help...Combi Boiler
    By Damian in forum General Chat
    Last Post: 13th April 2006, 18:48
