Thread: spax lowering springs
    Regular Member samngeorge1985's Avatar
    lanark scotland
    Default spax lowering springs
    has anyone out there put 40 mm lowering springs onto standard shocks and could you tell me if it will pass a mot with them on and if there is much difference with them, if i can save a pound with not buying shocks for the springs i will be over the moon but if i need to i will cheers
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Anything over 35mm should be on shorter shocks!! Upto 35mm will be fine on standard but they will wear out quicker!!
    HTH
    Regular Member 30ltr nutter's Avatar
    dunstable
    hi i put 30mm on my sri and all seems ok the origonal springs were 45mm
    Sunny Dartmoor
    An Sri is 15mm lower than standard so 40mm lowering springs will only drop your car 25mm,should be fine m8,i've just fitted 45mm/40mm Pi lowering springs on standard shocks and a few on here have done the same,hth.........
  1. Spax ssx springs
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2011, 11:38
  2. Lowering springs for a GSi?
    By cc123 in forum Handling & Braking
    Last Post: 22nd October 2010, 21:46
  3. Spax/Apex springs
    By Ben999 in forum Handling & Braking
    Last Post: 21st June 2009, 15:28
  4. Sorry, More questions: Spax or Apex Springs?
    By ectraz in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2009, 22:19
