Thread: Tyre sizes
    Leeds, UK
    Default Tyre sizes
    I currently have 205/35 ZR19 tyres on my Vectra C.
    I keep having problem because they are very low profile and it sounds awful when I hit a pothole.
    I have been told to put 235 tyres on instead. I have no what the spec is.
    Should I be asking for 235/35 ZR19?
    All feedback is appreciated. Thanks.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    As far as I know you should have 235 35 19 on anyway, with the tyres you have on at the moment your speedo will be 2mph out at 70mph.
    Saying that putting 235 35 19 on will make no difference to the ride quality as the tyre walls are the same size as what you have at the moment!!
    I believe the reduction in ride quality is just part of having 19's.
    HTH
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Quote Originally Posted by davree View Post
    HTH
    I dunno what tyre size you should haveI would have got some 19's but she didn't want the kids head shook around so that was a no no lol
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    235/35r19 is indeed the correct speed,if your speed is showing 70mph tour actual speed will be 67.72mph
    ...putting 235 35 19 on will make no difference to the ride quality as the tyre walls are the same size as what you have at the moment...
    Rubbish lol - the middle number (35) is a percentage size of the tyre width, in this case the sidewall height will be 35% of 205mm, with is less than 35% of 235mm as the proper tyre should be...
    Current sidewall height = 71.75mm
    New sidewall height = 82.28mm
    Almost 1cm extra. Not a huge amount and might not even notice, but there is a difference...
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by Penfold101 View Post
    Ooopps sorry, I forgot that he had 205's on and not 235's and confused myself!!
    Darn, and there I went through the calculator and everything...
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    205/35r19 diameter 626.1mm, Circumference 1966.95mm
    235/35r19 diameter 646.1mm, Circumference 2032.92mm
    the differences are -3.25% or -21mm in diameter and -65.97mm in the Circumference
  1. Which tyre sizes
    Last Post: 5th October 2012, 00:42
  2. Tyre Sizes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2011, 19:29
  3. tyre sizes
    By mrpatterson2008 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 17:50
  4. tyre sizes
    By chrissri82 in forum Handling & Braking
    Last Post: 4th June 2009, 12:59
  5. Tyre Sizes
    By Pendo in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2006, 23:02
