Thread: Ummm...sump plugs
    Regular Member Readster's Avatar
    Plymouth
    Default Ummm...sump plugs
    Amongst other tasks, I decided to change the engine oil & filter.
    I removed the undertray and got everything I need to hand.
    Could I remove the sump plug ? Could I hellaslike
    No way..I have the sockets that grip on the side of the bolt, a breaker bar to die for, WD40...and the b*****d rounded off on me. Nothing would shift it, hammer & chisel..nothing.
    Quick phone call to my mate in Stadium Garage Plymouth (quick plug..Ian & Martin are top blokes), it seems that VX use air tools and a steel plug into an alloy sumps will corrode and after 2 years its solid...
    Why 2 years? the car, prior to me getting it and been stored for 16 month,
    Martin will rescue me (again) with his air tools and a good amount of leg pulling !
    The moral ?
    Never assume
    Full Member spennny's Avatar
    Blantyre
    Assuming that your car (not yours, ingeneral) is serviced, oil changed yearly then the plug shouldnt have time to corrode ,
    Glad you sorted it, been there before
    Regular Member eaglepva's Avatar
    Up North
    Is your car a diesel mate? i need my oil changing asap and the cheapest i can get it done for at the garage is £60 Is it difficult removing the undertray?
    Plymouth
    Yes, I have a 120 1.9 Diesel. The undertray is easy enough with patience and room to roll around underneath the car. Wheel ramps or axle stands will do.
    £60 ? not bad considering the oil is £50 plus the filter & labour charge.
    I'm hoping that as I'm going to service this car from now on that the sump plug issue is a one off...
    Admin plasma's Avatar
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    Oil 5/30 is no more than £30 tops, filter £5. And a new sump washer if not a new sump plug if its starting to wear on the head.
  1. Dti sump
    By dwaine123 in forum Engine & Drivetrain
    Last Post: 13th January 2013, 20:32
  2. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  3. I've ummm got engaged!!
    By Jay Kay 313 in forum General Chat
    Last Post: 22nd April 2010, 12:54
  4. In The Sump!!
    By mitch1965 in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 18th August 2008, 09:07
  5. Sump Plug ?
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 14:59
