Thread: can u turn off traction control?
    burnham on sea
    Default can u turn off traction control?
    Took the car for a power run on the local rolling road, got the car on and was asked how do you turn the traction control off. Looked in the manual and you carnt, tried pulling out various fuses with no joy even went and got a t/c (esp) switch from vauxhall but didnt work it just lit up. Is there any way you can turn the t/c off so I can use the rolling road, would be greatfull if anyone can help.
    sorry my car is a signum 1.9cdti 120 8v, 04 reg
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    My only advice would be to buy the switch, but you have and it didn't work (seems 50/50 at best) I really don't think you can mate.
    From reading other threads though, doesn't it only work below a certain speed, hopefully someone else will come along and clarify.
    Cambridgeshire
    You will need to get the TC switch wired up. Someone on here has managed to wire it up correctly and got it working. Other than that it is usually pot luck on whether or not it works mate.
    Even if you got the switch working it will only disable the TC up to a speed of 30 mph (believe so) (i.e if you are traveling above 30 then the switch won't work).
    You shouldn't have problems using a rolling road if you have TC? All the Veccys and Signums on here have TC and they work fine on the rolling roads
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    as above the operator should be able to drive through the traction control
    burnham on sea
    Quote Originally Posted by parsco View Post
    as soon as the front wheels started turning the t/c cut in, wouldnt even get to 30mph
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    As soulman said, keep your foot in and it will turn itself off mate.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I have switchable TC, and when my car was rolling-roaded, the operator said he didn't need to switch it off.
  1. traction control
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2012, 17:51
  2. how do i turn my traction control off?
    By yatesy in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2011, 18:28
  3. Traction Control
    By Tam80 in forum Bodywork & Interior
    Last Post: 19th September 2010, 10:10
  4. traction control
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2009, 12:50
  5. Can you turn off the traction control
    By lee_eardley in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2007, 10:57
vectra c tc off
vectra c traction control turn off
vectra c traction control switch
how to turn off traction control vectra c
how to turn off traction contro signum auto
how to disable traction control vectra c
https:www.vectra-c.comforumshowthread.php80658-can-u-turn-off-traction-control
how to turn traction control off vectra
traction control how to turn off opel
how to turn off esp on vectra c
opel signum turn off esp
opel vectra esp turn off
vectra c disable traction control for dyno
2004 opel vectra yraction control light turn of
how can i turn off traction control off on my vectra 2.0t
traction control disable signum
how to turn tc off on vectra c
signum traction control off
can I turn traction control off a vectra c
z30dt traction coltrol switch off
how do you take traction control off my vauxhall signum 2005
vectra c activate traction control with opcom
how to turn off traction control opel vectra c
