Thread: Rattling rear hub
    Nottingham
    Default Rattling rear hub
    I've noticed a rattle from the rear nearside of the car which disappears when braking. There is no problem with the spring.
    I jacked the rear of the car up at the weekend to investigate further. I can recreate the rattling sound by rotating the wheel forward/backwards/forward. Each time I change the direction of rotation it rattles.
    Anyone any ideas?
    Regular Member mishima's Avatar
    UK
    Perhaps a warped disc? I have a similar issue to you on my car, I've been through various replacements to eliminate the problem - next one is disc's.
    Nottingham
    had wondered about that but it doesn't seem to matter where on the rotation the wheel is it still makes the noise. Would have thought a warped disc would have only affected one part. Also, when rotating the wheel there isn't any particular point where there is more drag than another.
    Isn't it quite hard to warp ventilated discs?
    UK
    Does this occur even when you are moving the wheel very slowly?
    Nottingham
    it occurs when I change the direction of rotation. I am only rotating the wheel a few degrees, not spinning it.
  1. Rear pads rattling like a MF
    By TerrySRIV6 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 20:17
  2. Rattling rear pads
    By tomo41 in forum Suspension, Wheels & Brakes
    Last Post: 22nd August 2011, 14:55
  3. Rattling from Rear
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2010, 20:29
  4. rattling at rear
    By evil.c65 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2010, 09:07
  5. Rattling rear brakes
    By h0llyw00d in forum Suspension, Wheels & Brakes
    Last Post: 3rd June 2009, 15:27
