Thread: Battery goes flat if left for 5 days
    Aug 2007
    bournemouth
    Default Battery goes flat if left for 5 days
    I have a 2002 vectra c 2.2 SRi I replaced the battery a few months ago as it was flat after a few days of not being used, as it was the original battery I thought it needed a new one . I have just left the car for 5 days and come back and it is totally flat. I have checked the current being drawn when it is idle and it appears to be 180ma but I am not sure if I am checking it correctly. I unlock the car disconnect the battery and connect the meter inline with the disconnected terminal and lead but is this the correct procedure to get the correct reading as there is the alarm, sensors and so much more on cars these days. I have check the obvious things like boot light and glove box light. How many milliamps should it draw when idle? Any help or advice would be appreciated
    Nick
    Regular Member stanian's Avatar
    Stafford, Midlands
    Trim : GSI
    Engine : 3.2
    Mileage : 45000
    I had a similar problem on my old Vecra B Sri, I had changed the stereo and fitted an autoleads adapter to keep my steering wheel controls. It turned out to be a faulty autoleads adapter i removed it and all was ok.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You really should LOCK the car with the bonnet open and holding down the alarm plunger. Then connect a meter between the neg of the battery and the cable clamp, and then disconnect this cable. That way you get a true reading of the LOCKED current draw.
    It may need a few minutes to stabilise though.
    If it is at 180mA (ie 0.18 A) then a truely 60 Ah battery would last for nearly 14 days.
    Apr 2009
    South West
    If you leave the car for 5 days with all alarms on the battery will go flat if the battery is older than a year. This is big business at all airports. if you ar in a secure carpark then lock car with the key on first stage only and that should sort out the problem.
    11 Post(s)
    The alarm will still set with one turn of the key. If you want to lock the doors without setting the alarm then you'll have to reach in through one of the other doors and press the lock button on the drivers door, then exit out the other door and shut it behind you.
    That aside, I've left my Vectra (nearly 3 yrs old with original battery) parked up for over a week before now and it's started straight away with no signs of a flat battery.
    Lastly, if you want to measure for current drain, it can take quite a while for the car's electrics to totally shut down due to the canbus network, which is still monitoring for something like ½ to 1 hour after locking up.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Bouncer View Post
    I would agree that batteries will go flat eventually, but after 5 days is too short a time.
    I regularly leave mine for 10 days with alram fully set and it starts no trouble, with an old battery too.
    Disabling the interior sensors will only do exactly that, the rest of the alarm is stilling working.
    Best to check battery current drain as I described above
    Surrey
    I left mine for nearly 20 days and started on the button.
    Would reading fault codes indicate any shorts to ground. Have you measured the alternator to see if it's charging the battery OK?
  1. Battery flat in 7 days
    By whitey in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2014, 00:25
  2. battery flat
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 14:26
  3. 10 Days Left to buy conventional Light Bulbs
    By 67688c in forum The 'Off Topic' room
    Last Post: 24th August 2009, 16:11
  4. flat battery
    By middler31 in forum Engine & Drivetrain
    Last Post: 20th July 2009, 20:55
  5. battery going flat
    By passatgop in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2008, 10:45
