Thread: Parrot MKI9200 Control Pairing Problem
    HULL
    Default Parrot MKI9200 Control Pairing Problem
    Hi
    I have just installed a Parrot MKI9200 , all powered up fine and connections ok , but ir will not pair with the Controller ,
    I have gone bt the instructions and Help the Green / play down while pressing Red button a few times but Nothing , the battery is new , so dont have a clue unless control is faulty. - Seems strange but the battery seems the rattle in the remote control..
    The unit finds my mobile ok , but obviously cant access anything until remote control is working.
    Anyone come across this problem before ..
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Switch on the ignition and let the graphic equalizer finish and display 'Parrot' logo, at this point press three buttons on the remote control at the same time. These are RED, GREEN and the PLAY/PAUSE buttons. You should see 'Pairing remote control on the display'.
    It may take several attempts to pair
    Surrey
    Quote Originally Posted by JACKALG1 View Post
    Hi
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    You have to do it with in 30 secs of power on.
    HULL
    Default Paarot MKI9200 Control pairing problem
    Hi
    Yes i have done it within 30 secs , even at varying times , in numerous differant orders just incase the instructions where wrong , still nothing , getting fed up now , as i mentioned in my earlier post , the CR2032 BATTERY sounds like it moves in the holder , very strange , the battery is in correct the 3v + faceing down.
    I have contacted Parrot , but not yet had a reply
    Many thanks for the Help
    Gary
    Surrey
    If it's loose it's not making a connection.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Hi
    Gary
    Did you phone or e-mail Parrot in Birmingham? I've found it's best to call them and you can go through the problem live in the car.
    UK Technical, User & Installation Support:
    Hotline: 0844 472 2360
    WGAF#5
    i found there was an anomoly with the parrots in that the remote HAD to be paired prior to the phone if the phone was paired prior to the remote then they wouldnt work - as it was completed out of sequence
    i refer you to user manual
    Before pairing your phone with the Parrot MKi9200, make sure that it is visible by all Bluetooth ® devices. To do so press the jog wheel and select Settings > Bluetooth >Visibility. Then, make sure this option is selected. If it is not the case, select it by pressing the jog wheel.
    which means the remote should be working as you have to use the remote to navigate the menu
    i ended up having 2 replacement units because of this
    hth
    regards
    HULL
    Default Parrot MKI9200 Control pairing problem
    Hi , Thanks for the replies
    With ref to the problem pairing my phone before the remote control , thes this was the case , it did pair before anything else was done.
    The problem is , because the remote will not work , i cannot access the on screen menu to do anything at all , the screen just sits in the ` Parrot MKI9200` startup cloud screen .
    Is there any other way to reset the master control box , as if it is a case of the phone causeing the problem , there is no way to reset it.
    WGAF#5
    there is no way to reset the box - remove it and take it back to where you got it from - i was on first name terms with the carphone warehouse team following my fiasco - parrot support will take more than 5 days to respond via email - a phone call will get a response normally within an hour if you dont connect to someone - and they will say - take the blue box and the remote back for an exhange
  1. Replies: 8
    Last Post: 20th March 2013, 10:12
  2. Anyone near me able to help. (Parrot mki9200)
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 20:59
  3. Parrot mki9200
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2012, 20:51
  4. parrot MKi9200
    By chay6684 in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2010, 10:55
  5. Parrot MKI9200
    By chris_20 in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2010, 15:10
parrot mki9200 problems
parrot mki9200 reset buttonparrot mki9200 not workingparrot 9200 remote not workingbattery for parrot mki9200 remotepairing parrot mki9200pair parrot mki9200parrot pairing mki9200 pair without remote controlparrot mki9200 control pad not workingparrot mki9200 screen not working
