Thread: radiator fan problem
    huddersfield
    Default radiator fan problem
    hi all thanks for the welcomes,
    i have a temperature problem on car in slow traffic (motorway tailback) sub 40 mph the temp krept up above 100 degrees indicated and with it being a 2.2 with air con button i wondered how many fans where meant to come on ? also whats best to check first ?? the car cooled back down to normal once i was able to get some air flowing again 60 ish any help would be great cheers
    Full Member Big Sig's Avatar
    Could be the thermostat. I'd leave it running on the drive and see if the fans come on or not
    May 2006
    scotland
    Yep, as he said. Also if your stuck in traffic, try your heater to cold setting and switch on the air-con. For some reason this reduces the water temp in the engine (well it does on mine) when standing in traffic.
    milton keynes
    If the fan wasnt coming on you would get the dreaded 'car and spanner' icon. This would tell you fan control circuit no.1 is open , if you know any kind fellows in your area with laptop diagnostic tools / tech2 you can switch on fans at all 3 stages to make sure they are functioning. Just a thought but have you checked there is enough coolant in the reservoir , this again should throw up an error if too low.
    Quote Originally Posted by wickedwillie View Post
    Thats because the A/C brings on another fan to cool the refrigerant which, in turn cools the water rad as they are all together.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. new radiator
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 11:33
  3. help with radiator
    By dcm23251981 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th March 2012, 01:51
  4. radiator problem
    By gangleyshag in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 14:14
  5. air con: radiator
    By bloodworm in forum Engine & Drivetrain
    Last Post: 21st February 2009, 17:08
vectra radiator fan issues
