Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: handsfree installs
  1. #11
    Feb 2006
    Dorset
    everything needed for the phone to operate through the stereo is there , blue and brown wound together are audio in red is 12+ve brown is ground , one black is ignition one is radio mute . its easier to by the lead than to hack it all about unless you have a multimeter handy and know what your doing .
  2. #12
    Regular Member Ben H's Avatar
    Herts\Beds Border
    But remember the plug may not be there so don't beat yourself up all night looking for it. It's quite obviouis if it's there. Most of the time it's there if you have a large base to your radio aerial as opposed to the small ones you see on all Vauxhalls, these larger aerial bases has the GSM aerial built in so that's a quck way to check without pulling out your glove box.
  3. #13
    North east HQ
    how easy does the glovebox come out, ive been quite lucky in that all the plugs ive looked for have been there, ie. rear interior light,traction control etc
  4. #14
    Feb 2006
    Dorset
    5 T20 torx screws 3 at the top 2 along the bottom , then it pulls out .
  5. #15
    Regular Member thewww2's Avatar
    London
    another tip is if you crack open the mic that comes with the 7w kit and just use the mic without its housing its a perfect fit in the space between the alarm sensors in the roof near the interior mirror,
  6. #16
    Feb 2006
    Dorset
    And the result is you get pig awfull background noise. been out to service calls to rectify that problem , the nokia mic is directional removing it from its housing does it no favours .
  7. #17
    London
    I did pack it in with some sticky foam behind it to stop any vibration , i had no complaints so far.
  8. #18
    Herts\Beds Border
    I have too and it's not too bad, not as good as what it was in Corsa but put that down to differant car as it's only road noise, oh & the wipers are much clearer to hear now.
    I also cut the button up & mounted it into a switch blank as you don't need the rotary dial bit to adjust volume as that's done on stereo.
  9. #19
    North east HQ
    any pics of these mods they sound a bit neater than just sticking them to the dash, any suggestions where to put the brain
  10. #20
    London
    i used the autoleads lead and fitted the nokia box behind the glove box on the far left above the passenger side kick panel, i secured it with a couple of cable ties ,its the easiest car kit Ive ever fitted, i fitted a cheap gripper type phone mount on the passenger side middle air vent and routed the pop port lead to my phone out of the glove box when not in use i just tuck the lead back into the glove box,
  1. boot installs
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2011, 00:52
  2. Handsfree help!
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2011, 20:31
  3. your sub installs please !
    By sdnatlst in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 10:00
  4. Handsfree Kit..
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 23:23
  5. help with handsfree req
    By dukedog in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2007, 23:08
