Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: handsfree installs
    Full Member chunkster's Avatar
    North east HQ
    Default handsfree installs
    has anyone fitted the nokia ck-7w hands free car kit to the veccy?
    is it easy to do with the canbus??
    can i do it myself or should i get someone else to do it???
    ...............and will middlesbrough come back from the brink yet again????????????????????????????????????????????? ?
    Wayne -
    Preston Area
    Did it on mine.. but it did have the phone plug behind the gove box.... dead easy to fit if that's there.. otherwise consult siocommunications, the guy who runs it is the dogs danglies and he'll be able to sort ya out with the correct wiring harness which will fit in between the existing wiring and the head unit - not cheap but worth it
    Regular Member Ben H's Avatar
    Herts\Beds Border
    I fit em for a living, as bruceybonus says it's a doddle if the VDA plug is behind the glove box otherwise it's a little trickier.
    What year or radio do you have? Both ISO & Quad lock connections have phone input pins on back of so if you don't have the phone prep'd loom you can wire straight into back of radio then all you need is an ignition feed.
    Jan 2006
    Dalriada
    never mind the hands free how about boro!!?? unbelievable
    Feb 2006
    Dorset
    Vectra's are a doddle . if you havent got the vda plug just get the quadlock interface lead from autoleads , and remember to secure the mic cable when running down the a pillar to keep it away from the airbag .
    North east HQ
    thanks everyonne, i cant believe the football (i know this is a car site) time for some more beer, good job im not at work tomorrow
    Wayne -
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Fitted a hardwired one for my Nokia 6100. There was no pre-wired harness in the car at all.
    Still, sound come through the main stereo and music is muted when in calls.
    The harnesses mentioned above may be quick, but they cost £25 upwards which is not cheap for 3 wires from the brain to the back of the stereo. I posted what wires go where some time before on here.
    Real easy to do though.
    North east HQ
    so whereabout is the plug behind the glovebox, does anyone have any pics of it, do i need any extra connections or cables to match the plug to the nokia system, do i have to take the box out to get to the plug
    Wayne -
    Feb 2006
    Dorset
    Remove the glovebox and it will be wrapped in masking tape on the righthand side taped to the radio loom , you will need a autoleads vda lead and it will then just be plug and play you may also find the ariel as well terminated with an FME .
    North east HQ
    ok cheers dennis, something to look for when the mrs comes in
    do i still need to connect to the battery or all the power points in this plug
    Wayne -
  1. boot installs
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2011, 00:52
  2. Handsfree help!
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2011, 20:31
  3. your sub installs please !
    By sdnatlst in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 10:00
  4. Handsfree Kit..
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 23:23
  5. help with handsfree req
    By dukedog in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2007, 23:08
