Results 1 to 10 of 13
Thread: Water Pump Problem?
    West London
    Default Water Pump Problem?
    Hi all,
    Just had AA look at my motor. Came back from brighton yesterday and as i reached home i heard lots of noise coming from the engine. Sqeeking and Clicking coming from the right hand side of engine (if infront of car, by the belts) also a lot of water above my o/s front wheel axl.
    AA patrol advised water pump is knackered and needs replacing. How much should i be looking to pay for this doing? Its (over)due for a service so would be looking to get this done at the same time.
    Thanks!!
    Mileage : 000
    Sounds like the bearings and seal has gone in the water pump. I don,t know the milage of your motor. But it might be a very good idea to get the cambelt and all the pullies and the tensioner changed at the same time.
    West London
    cheers for that, forgot to say its a 1.8 petrol club 05. 45k on the clock. service center said the belts wouldnt need doing at the moment - should i still get them done in light of this?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yes, get the cambelt done if, as has been said on here, it is a good idea to get the water pump done at the same time.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    dont mess around, get the cambelt and tension and idler pullys changed when doing a cambelt, as once the cambelt comes off, they say you shouldnt refit it
    Mileage : 000
    I would recomend a cambelt change at 40k. In my opinion you are overdue a cambelt change now.Best to be on the safe side. It can work out cheaper.
    West London
    cheers for the help guys, guess thats me on the pushbike untill i can afford it! cheers!
    West London
    just been getting some quotes today, VX quoted nearly 700 quid!!!, lowest i have is;
    timing belt kit - 79 quid.
    water pump - 33 quid.
    labour. 75 quid.
    £187 quid all in - good or bad?
    Quote Originally Posted by mattster87 View Post
    labour. 75 quid.
    that is VERY good mate
    Quote Originally Posted by ks246 View Post
    I would book it in as soon as, hope they do a good job any recomendations ................
  1. 2.2 se water pump/ temp gauge problem.
    By james chambers in forum Engine & Drivetrain
    Last Post: 29th June 2012, 20:31
  2. 2.2 se water pump/ temp gauge problem.
    Last Post: 19th January 2012, 02:13
  3. Water pump?
    By Tigger in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 23:00
  4. Possible water pump problem
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 15th July 2010, 19:55
  5. Water pump
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 18:55
vectra water pump problems
