Thread: What do I loose?
    hull
    Default What do I loose?
    I have finally got fedup with lack of Mp3 function on my cdc40 and have started looking for a replacement but.....I like the DAB as I listen to Kiss100 london and I also like the info screen for mpg etc etc. What Id love anyone to help me with is if I replace the head unit more then likely with a double din dvd one will I loose the display, will the cdc40 be any good to anyone without the screen and how much could I get for it roughly ?
    Also is the DAB unit built in to headunit or is it seperate? If its seperate can I use standard unit with aftermarket headunit
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    For the radio to be of any use to anyone is must be unpaired first. DAB is a seperate unit, tucked up someone near the glovebox area i believe and no you would be able to use it with another radio that i know of/
    hull
    Found this
    http://www.alpine-electronics.co.uk/...de-w203ri.html
    and caraudiosecurity have a few leads it says I need for steering wheel controls. Could anyone tell me what I would need to retain these controls and have full intergration with the car? Also if I change to this is it still possible to retain the standard display with MPG etc??
    Regular Member Hs2300's Avatar
    yorkshire
    Quote Originally Posted by DaveD View Post
    why not ask on JOV fella lol
    hull
    Now then big fella what you doing on here lol
  1. Loose frontend
    By Jabbekot in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 14:09
  2. Loose rear end...WHY?
    By BlueRob in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2008, 19:15
  3. Loose rear end...WHY?
    Last Post: 29th July 2008, 18:33
  4. At a loose end???
    By marichrd in forum General Chat
    Last Post: 27th June 2006, 21:51
