Results 1 to 10 of 11
Thread: Pre-facelift front bumper clips
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Default Pre-facelift front bumper clips
    Can anyone who has had their front bumper off please help with this? I need to release the bumper enough to get to the top bolt of the offside fog to replace it (mine's cracked and I have a replacement bought a while back from another member).
    Followed the how-to on here and got the screws undone etc, but I'm stuck with the clips on the underside of the bumber. No matter if I push the centre clip up or pull down I can't get the studs to release. I'm reluctant to pull too hard in case I break them. Just how far do the centre pins need to be pushed in? (or pulled out!). Do these need much force to pull them out?
    The following is a photo of the clips I mean
    Thanks in advance
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Push them all the way out mate, they are just plastic rivets. Pop the centre out then pull down on the bumper to release it!!
    HTH
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    You cant push them upwards because of the head on them, Pull the centre bit all the way downwards and out, i normally use a pair of pliers to grip the centre bit, then the rest of the rivet will come out with a wiggle.
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by plasma View Post
    Oh yeah!!, sorry I forgot they aren't the same as the ones on side skirts - Looks to me from the piccy that the head has snapped off that one!! The ones on mine were quite a lot wider than that!!
    As Plasma said use long nose pliers and just pull the centre bit out!!
    Feb 2007
    North Somerset
    OK thanks - I was getting confused by step 2 in this http://www.vectra-c.com/forum/showthread.php?p=188334 how-2 and trying to push them upwards - I'll try again pulling them out this time! I'm assuming they can just be reused?
    Regular Member c5clive's Avatar
    Apr 2009
    church village
    Quote Originally Posted by MysteryElite View Post
    Thanks in advance
    pull the pin right out, they need a good pull, do all four then ease bumper down, don't break or lose them you'll need them to refix. It is a very easy job to take the bumper off completely, three fixings in each wheel arch, two under bonnet, pull bumper out by wheel arch that's it takes about 5 minutes
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Yes mate or cheap as chips from the dealers.
    Jun 2009
    Mid Wales
    Default Bumper Removal
    Quote Originally Posted by c5clive View Post
    Unless all three on both sides are rusted and stuck in the clips - then it's a pig of a job!! Had to drill out the screws in the end. Don't forget to undo the washer bottle pipe first too, otherwise it'll break the elbow joint - speaking from experience I'm better off left with my crayons.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Top Tip: When you put the clips back, dont use the pins in the centre, just push the main clips in and then put screws in the middle, I found that black plaster board screws are the perfect size for this, they grip enough to screw in and out correctly and hold the clip in place. If you ever need to get them off again, you just unscrew the screws and the clips fall out, no yanking pins out and smacking your knuckles on the ground
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    depends how big your knuckles are lol, I use a pair of wire cutters to grip under the head and then just ease the pins out
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
  2. Will the facelift front bumper fit the pre-facelift model?
    By thicknickdjn in forum Bodywork & Interior
    Last Post: 26th September 2011, 21:37
vectra front bumper clips
