Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Blown turbo advice needed !!
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    confused Blown turbo advice needed !!
    Well my 1.9 cdti 150bhp has now gone and obliterated the turbo !
    Now spent £3400 on repairs from the 10th of febuary and my patience (and wallet) are begining to wear thin , had a clutch,flywheel,inlet manifold, timing belt thermostat new shocks springs discs and pads all round new rear anti roll bar bushes and rear upper control arms then the drivers window regulator snapped and the turbo blew !!
    Problem is the new turbo is now on but the car still wont start the mechanic has tried for 2 days (he is a usually good independant)!
    Does any one know if the tech 2 is needed to reprogramme the engine after this work has been done ??
    Thanks in advance
    Andy
    newcastle upon tyne
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Turbo doesn't need tech2 mate not sure why it wont start unless he's left a wire off or the turbo could of done more damage than first thought
    newcastle upon tyne
    The more damage thing was whatt i was worried about !
    Hope it hasn't knacked nothing else
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Was any of the fins broken off ? tbh i think you would of been lucky not to damage any thing else best to check the fins on turbo and you might be best taken head off that's my opinion but some one else might tell you different
    newcastle upon tyne
    Never got to see the broken turbo as dealers who delivered new one took it straight away to avoid the surcharge dont know if mechanic paid it any attention
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Bit strange the first thing i would do would be to check fins to make sure none were broken as they would of got sucked into engine,I'm sorry mate but without the turbo to check you would have to assume that the turbo blew and damaged your engine coz if it was just the turbo and assuming the garage have fitted it right there should be no reason why the car shouldn't start
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you say you have had a clutch / flywheel replaced ? .........all at the same time ?
    preston
    Just sounds as though fuel 'aint getting through, does it try to fire at all when cranked?
    preston
    obliterating the turbo could have blocked the cat solid and stop it running
  1. about to fit new turbo advice needed
    By john norris in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 19:12
  2. MIght have blown my turbo Help!!!
    By Mrmac in forum Engine & Drivetrain
    Last Post: 13th July 2012, 10:05
  3. Turbo Blown up!
    By Chewonit in forum Engine & Drivetrain
    Last Post: 18th July 2011, 16:25
  4. Turbo Gone - Advice needed
    By Landers in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 00:06
  5. BLOWN TURBO ? 2.2 dti
    By nev-vec in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 10:19
