Results 1 to 10 of 11
Thread: Cruise control ?
    glasgow
    Default Cruise control ?
    what could stop cruise control from working when i press it on the stalk it does nothing any idea's people
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    90 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I seem to remember people having a problem with a pedal sensor or switch, might have been the brake one..
    May 2007
    Home or in the Gym
    90 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Have a look here
    haworth
    i had the same problem on mine and it is that the clutch pedal sometimes does not return fully to the top, simple way to cure the problem; when changing gear into 5th or 6th just simply lift the clutch up with your left foot, its only a small amount of lift needed and it solves my problem
    hope it works for you
    glasgow
    thanks guys ill take a look
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    You can buy a spring from the dealers that you fit under the clutch pedal.
    Its about 4" long and once fitted the clutch pedal is firmly at its highest position.
    This means that the switch is in firm contact with the clucth pedal and not turning off your cruise control.
    The spring is about £5 and takes 30 seconds to fit.
    Scotland
    I have this problem too, funnyily enough, my fix was to switch down to 4th then back to 5th and it worked.... gonna have to look at getting a spring fitted too me thinks
    glasgow
    Ive lifted the pedal ,switched from 5th to 4th and still nothing could it be the stalk ?
    [Ex]Admin Duncan's Avatar
    Could be - just to check, have you made sure the brake pedal has been pressed at least once before trying to engage CC? It won't activate otherwise - often catches people out when leaving motorway services. Also it won't activate under around 30mph - just in case you'd been trying to.
    glasgow
    yeah done it at 40 50 60 70 lol light wont even flicker and pressed the brake b4 it
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
