Thread: Help needed
    Regular Member zazaszazas's Avatar
    Cumbria
    Default Help needed
    Here is my story.Started the engine last night and Abs plus traction control light stayed on for some reason.....My question is it a trip to the dealer for me and need to be Tech 2'd??
    Full Member spennny's Avatar
    Blantyre
    Might be wrong but have you checked pads ?
    Cumbria
    Quote Originally Posted by spennny View Post
    checked the pads no problems there
    Worcs/Staffs/Westmids (ish)
    How does the ABS work on these?
    I honestly have zero idea!!!
    But if it's an ABS ring around the CV joint (looks like a little ladder wrapped around it) it could have split open meaning the car (via a hall sensor) doesn't see the one wheel rotating and has a spaz, the same sensor is probably used for the traction control. Hall sensors are magnetic so the broken ring sticks to it instead of rotating with the wheel.
    This ring split on my 306, so I tied it together with wire and glued it back in place, worked a treat for 2 years until I got round to having it welded :P
    Just a thought off the top of my head.... VX might do things differently.
    Cumbria
    i've had the car tech2'd and its says my front wheel abs sensor is faulty(open circuit)..That means i need to get a new wheel hub coz i can't buy the abs sensor separately..well
    WGAF#5
    some times corrosion builds up on the abs sensor -causing it to incorrectly "space" - you might be able to clean it up and the fault should clear ?
    hth
    regards
    Dez
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    give it a good clean m8 and it might sort it
    As I suspected! kinda!
    I was told my 306 needed a full driveshaft at a cost of £180 plus fitting. Tis why I bodged it :P
    Oh and the sensor wont be mounted on the hub, the ABS ring will be.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It could be the connector on the suspension leg. Water gets in, causing corrosion of the terminals, and hence non circuit.
    I would seriously check out the front ABS sensor wiring connectors and see if it is the problem, people have saved some cash by looking at these before.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
