Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: brake pipe need replacing
  1. #11
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    they are being rather greedy with a price that high , the main one to be aware of on the vectra C is the one which goes across the top of the fuel tank from the offside to the nearside rear .
    there is a small part of this pipe ( about 3 inches ) that cannot be seen once fitted & this is where it rots badly , recently replaced a burst one on a 56 plate car & the rest of the pipes on the car were like new .
    I would replace this pipe as a matter of course rather than wait for it to burst .
  2. #12
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Thanks for your advise about the 3" pipe, something that wood get missed if you didnt know it was there.
    Will shop around an independent garage and see what price they come up with.
    Thanks.
  3. #13
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    I was quoted £250 off one garage and £150 off another
  4. #14
    Regular Member steve_c's Avatar
    Jun 2012
    Cramlington
    I do them for £35 (70) for both front to rear,
  5. #15
    Regular Member eaglepva's Avatar
    Up North
    when i had my signum i had to get them done for the mot got the lot done for £65
  6. #16
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Quote Originally Posted by OPC View Post
    When I took my 08' Vec C in for it's 1st service I had a chat with the mechanic whilst having a look under the car. I asked him about long term ownership and preventative stuff. He agreed with me on the EGR valve and DPF.....the other thing he mentioned was Brake Pipes, said that they could be prone to corrosion. I was a bit suprised and I thought they'd addressed this with the Cavalier Mk 3 when they used the green coated pipes.
    I was thinking maybe I would coat them with waxoil.
    i wouldnt coat them in anything, what if they do corrode badly and you cant see it until the inevitable happens
  7. #17
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    dealers would probably replace them with bundy tubing whereas indie garages would probably use copper piping
  8. #18
    Jan 2014
    Leicester
    Trim : LS
    Engine : 1.8 petrol
    Once again it only serves to demonstrate that the vast majority of VX dealers are money grabbing hogs. Sadly it is Vauxhall who set the costs by their set scales of job pricing which is mandatory for the dealers to follow. Try and get one of their mechies to do the job on his own time cos some dealers allow their own staff to use the ramps when they are free. There again its easy enough and cheap enough to buy the kit yourself and graft in a new section or re-route the whole pipe. As long as you do not disturb the ABS valve unit. I tend to cut and graft where the pipe appears at the bottom of the engine bulkhead and turns towards the rear of the car. If you re-route the pipe around the fuel tank remember to use body clips to secure it to the body. Loose pipes will fail too.
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. brake pipe help
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2012, 08:00
  3. Replacing brake disks
    By shchuka in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2012, 18:26
  4. Replacing Brake Discs And Pads Help!!!
    By dti owner in forum Suspension, Wheels & Brakes
    Last Post: 27th April 2011, 20:20
  5. Replacing Brake Discs - new caliper carrier bolts?
    By markconlen in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2008, 23:32
https:www.vectra-c.comforumshowthread.php80414-brake-pipe-need-replacing
vectra brake pipe replacement
vectra c rear brake pipe replacement
vectra c fuel tank removal
zafira brake pipes corroded
vectra c brake lines
brake line replacement cost vectra c
cost of brake pipes for astra 2008
vauxhall vectra brake pipes
os brake pipe vectra c
are vectra prone to break pipes rotting
front to rear brake pipe location vectra
brake pipes vectra c
diameter of brake pipe vauxhall vectra
vauxhall vectra c 1.9 rear brake pipe
vectra c sri cdti 2004 metal brake pipes
Vauxhall vectra 1.9 cdti brake pipe
nsf brake pipe for vectra 52 plate
brake pipe issues on a vectra
how much does it cost to replace a brake pipe on a vauxhall zafira 1.6 2004
vectra c silver pipe under car
vectra brake pipes
brake pipes for vauxhall vectra
cost of brake pipes on vauxhall vectra 1.9cdti darlington
cost brake pipe vectra c
