Thread: Heeeeeeeeeeeeeeeelp!
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    Default Heeeeeeeeeeeeeeeelp!
    I just had the EML come while demoing the map to a mate.
    Car is runing fine, no miss fire or fluids anywhere, no smoke.
    Turbo is boosting, but car is just not pulling as it should.
    Any advise/heads up on what it could be as im currently 70 miles from home at a mate house?
    __________________
    WGAF#5
    disconnect the battery for 20 minutes - hard reset and hope the fault clears
    sorry mate best i can suggest at this time of the evening
    good luck
    Dez
    Jan 2006
    South Wales
    good luck
    Dez
    Cheers mate, appriate it.
    Not tried disconnecting the battery, was worried baout loosing my map, but ill try that.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    map is hard coded into the ecu and will be fine
    Jan 2006
    South Wales
    cheers guys, will try the in the morning.
    just on pins atm hoping its not the turbo.
    cheers again guys.
