Thread: Fascia around head unit
    Kent
    Default Fascia around head unit
    I had a look at fitting my head unit today and I have 2 issues, the first is I bought the fascia in Black - I either need to spray it to match the car or buy a different one which matches the car as the black stands out to much, any advice on this would be helpful.
    The 2nd issue I saw was the cage doesnt seem to secure in the fascia so once fitted you could just pull the whole stereo including cage forward with no effort, what was I doing wrong?
    Because of these issues I didnt bother fitting it today, as to the colour of the fascia, its hard to explain but the rest of the buttons are charcol / grey.
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    you can buy grey (gunmetal) facias
    secondly some aftermarket facias are not a good fit.you may need to buy the cage and facia together.hope this helps
    Kent
    ok thanks, is it worth complaining about the one I bought as the cage is not secured at all
    Kent
    Well I contaced the seller and explained the cage wasnt secure and they replied saying there are lugs on the cage which need to be bent outwards, but I looked and couldnt see any, has anyone experienced this before?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    maybe it might help ppl if you posted up a few piccies
    Quote Originally Posted by fattony View Post
    Most cages should have lugs.They look like cut outs in the metal,you just prise them with a screw driver or something to catch into part of your stereo space.Can you put a photo up so, We can maybe advise
    Beaten to it
    Kent
    Thanks got it sorted, you are correct the lungs are inside top bottom and both sides, I was expecting them on the outside of the cage but all is good, just need to decide if I should spray it gun metal or buy another facia
    Glad you got it sorted.As long as its in, you can change the facia at a later date
  1. Which fascia/wiring adapter will I need for this Alpine head unit?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 17:00
  2. new head unit
    By dazzie66 in forum ICE Gallery
    Last Post: 19th September 2010, 20:31
  3. What head unit does...
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2007, 02:09
  4. Want a new head unit but...
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2007, 20:28
  5. New head unit help
    By neilshaw1980 in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2007, 19:48
