Thread: Brakes
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Brakes
    Hi guys, today i set about changing my brakes but was stumped by the carriers. How do you remove them? Ive got the right torx bit but cant release the bolt! Any help before i get to p***ed of and take it to a garage?
    PS. Ive established shouting at it doesnt work!
    They're jsut on really really tight mate. Get more leverage and a longer pole. Like a diesel, torque is the key....
    Mileage : 000
    A long breaker bar with an e20 torx socket should do it. They can be Very tight.
    Try a bit of heat on the bolts as well. Theres a thread locking compound on them.
    ...with that oxyacetelene torch you've got lying around...
    Otherwise, try a match and a can of deoderant...
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    its because they have thread lock on them
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by ed taylor View Post
    Its E20 for the fronts and E18 for the rears.
    Quote Originally Posted by glynn View Post
    Fronts are torqued to 230Nm and the rears are 130Nm aswell as the thread lock
    Just done mine all round, when using the breaker bar it's best to "rock" or "bounce" the bolts free as if you just use brute force you can shear the heads off as my mate found out!!!
    Belfast
    Someone needs their Weetabix.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
