Thread: Any washing machine engineers on here?
    Lancs
    Default Any washing machine engineers on here?
    Have a problem with our indesit!
    Mileage : 000
    What is wrong with it. Someone might has an answer to the problem.
    Lancs
    No hot water going in.
    We have tried the hose and is ok water coming through.
    We have changed the hot water inlet valve in the machine and there was no change.
    Any ideas?
    Mileage : 000
    I take it the inlet valve is a sort of solinoid opperated one. Is there electricty (power) going to it. I wonder if the programer is not telling the inlet valve to open??
    Halifax
    I know with ours there was something blocking the water emptying so it could be the same with going in?
    Becouse if its blocked somewhere then it won't allow water to go in?
    I know the inlet valve is controlled by the machine itself so if the machien controls the valve and its blocked then maybe thats the problem?
    Or maybe part of your circuit board has gone as that has happned to us
    Well the washing machine packed in bougth a new one then the drier blew, swears, so i was down a grand.
    It always happens when your saving your money grrr
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    does it run a cycle normally, just without thre hot water ?
    if yes probably solonoid, if no more likely control panel or thermostat.....to be honest its cheaper to buy a new one than mess about in them
    Lancs
    It runs the cycle perfect. just on cold
    We have changed the solonoid and no difference - doesn't even heat up the cold water?
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    Quote Originally Posted by MrsJR View Post
    same as ours did beginning of this year . had to have a new computer unit for it,,, they are now in 2 parts 1 ecu and 1 chip then the thing has to be programmed up.. ours under extented cover ,, but guy said would be looking at £175 to off done the job..
    is the element broken? test it with a fluke and see how much ohms resistance you get....id imagine it`d be under 100 ohms.... if its infinity or kilo ohms its dead lol
    im guessing it has an element - does it only have a cold input not a hot as well ?
    sometimes also at the pipes at the back there are filters for the water, you could try that as well but like i said, probly easier to buy s new one
  1. broken washing machine
    By john norris in forum General Chat
    Last Post: 22nd December 2012, 16:25
  2. phone v washing machine
    By beat275 in forum The 'Off Topic' room
    Last Post: 20th November 2012, 16:50
  3. Broken Washing Machine
    By John Bishop in forum Comedy & Humour
    Last Post: 14th June 2012, 16:56
  4. Washing machine
    By LOCKSTOCK in forum General Chat
    Last Post: 2nd February 2009, 05:24
  5. Washing machine inlet valve
    By thegoldenbullet in forum General Chat
    Last Post: 11th November 2007, 11:39
