Results 1 to 10 of 13
Thread: do you need new wheels bolts when swapping from steelies to alloys
    Default do you need new wheels bolts when swapping from steelies to alloys
    Calling all LS owners and knowledgable folk!!
    after a few comments in my recent thread thought i'd just put my mind at rest
    http://www.vectra-c.com/forum/showthread.php?t=80136
    so when swapping from vx steel wheels and trims to vx standard alloys (not aftermarket wheels) do you need to swap bolts?
    i never have on any other car i've upgraded?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    steel wheel bolts are black, and alloy wheel bolts are a bright silver/ crome ish
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    sie wise ok ,but will look nicer with some nut covers
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    It is safer to change the bolts when changing from steel wheels to alloys.The bolts from the steel wheels can cut into the alloys and make them come loose.Slightly diifferent angle and also the steel is a lot harder material.Also recommended if changing back
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    As stated it would be strongly advisable to change to the correct bolts for the type of wheel being used. Indeed, I believe its a safety requirement.
    I remember when I bought my caravan new, that although it had alloys fitted, it came with a spare set of bolts in case I ever had to use the spare wheel which was steel. The caravan fitter said it was dangerous not to use the right bolts.
    bumpage, any others actually had problems then?
    Quote Originally Posted by ks246 View Post
    The reason I put the post up ,was because a friend of mine changed his steel wheels to alloys on a seat toledo,after driving for a while he noticed a shake in the steering wheel.This became worse.When he stopped the car the front wheels had become loose.The steel bolts had actually cut away part of his alloys.It cost him two new alloys and was recommended never do that again as it happens quite alot.Better to be safe then sorry
    was he fitting an aftermarket alloy though ?just wondering if the hole taper might have been differnt or something like that, i was genuinly suprised by the comments in my other thread having never heard of it.
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    i have always been told you need to use alloy wheel nuts on alloy wheels
    Quote Originally Posted by aerodynamic18 View Post
    well you live and learn as they say. i'll have to get some sorted then.
    does everyone on here originally fitted with alloys have silver bolts then? why do they bother putting the black plastic covers on them?
    anyone have any links with the correct bolts from when they bought some?
    ta
  1. 18's alloy to 16" Steel Wheels? Steelies Better?
    By mucklestone in forum Handling & Braking
    Last Post: 25th October 2010, 17:57
  2. Facelift sri alloys on prefacelift sri car, after swapping!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 00:28
  3. Swapping tyres on Alloys
    By karldower in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2009, 20:16
  4. Swapping Wheels and Tyres
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2005, 11:31
