Thread: rear fogs
    Edinburgh
    Default rear fogs
    I thought one of my rear fogs had blown however I replaced the bulb and it still didn't work. I then noticed that the passenger side connector has one less wire than the drivers side and it's the drivers side one that works. Should my vectra only have 1 rear fog? It's an 06 facelift SRi
    One fog is standard mate - it allows you to tell where a car is if you're in thick fog and on a motorway and all you can see are the fog lights. The fog is on the right hand side, so you know the rest of the car is on the left of it...
    Full Member spennny's Avatar
    Blantyre
    Unless you do the mod as i did, but dont tell ste
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Penfold101 View Post
    ...or if both lights worked the car would be in the middle of them.
    As Penfold said, it's normal and something you'll see on other makes too. There's only a requirement for one rear fog light - it also means it's easier to differentiate, when in thick fog (which of course it would be as nobody uses their fog lights in anything else but - if only! lol) between fog lights and brake lights.
    Regular Member gaz4d's Avatar
    Glasgow
    Here's the How 2 for doing the double rear fogs.
    http://www.vectra-c.com/forum/showthread.php?t=41022
    Edinburgh
    thanks chaps, was just a bit worried since the veccy is booked in for it's first MOT a week on Mon and I didn't want it failing for one of the fogs not working. interestingly despite the lack of electrical connection there was a bulb in there!
    It's going into a Vx stealer for it's MOT so hopefully they'll know it should only have 1 fog light
    pmsl
    Quote Originally Posted by knoxvillain View Post
    Yep, that one is a spare. Seriously, it mentions it in the owners' manual about it being a spare bulb.
    One would hope! - although then again!
    pmsl
    Blantyre
    It's going into a Vx stealer for it's MOT so hopefully they'll know it should only have 1 fog light pmsl
    Mr MOT man didnt notice mine
    11 Post(s)
    Quote Originally Posted by spennny View Post
    That's because the requirement is only one has to be working.
    http://www.motuk.co.uk/manual_110.htm
    "The inspection of rear fog lamps is confined to the one rear fog lamp which is required to be fitted to the centre or offside of vehicles first used on or after 1 April 1980."
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
  1. Rear fogs FL Signum 1.9
    By fishphone in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2011, 20:26
  2. Vec c rear fogs.
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 00:54
  3. Rear Fogs
    By JohnSH8892 in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 12:05
  4. Rear Fogs
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2007, 20:28
  5. Rear Fogs
    By Neil in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2007, 13:06
