Thread: Possible suspension issue
    Regular Member chris_1d's Avatar
    Cambs
    Default Possible suspension issue
    Hi guys,
    Whilst having a spirited drive home last night I found that when cornering to the left, I felt as if I was leaning very right...but when cornering right I hardly moved, apart from the obvious forces...
    The car has only done 46k, and is covered by the Network Q warranty + remaining balance of the manufacturers warranty...
    Any ideas of a cause??
    Chris
    May 2008
    Tyneside
    Could it have been an adverse road camber? If not I would suspect a weak/broken spring. Does the car sit level on level ground?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Given that both springs and shocks give problems on the C, I'd have a look at both.
    Phil
    Cambs
    Its gong into vauxhall on tuesday. Apparently the 6th or 7th vectra with suspected broken springs this week! Described the problem to them..then I got the workshop controller who said don't drive it and bring it into us now...I pointed out I was at work and they said ok, tuesday, 7.30am...
    Ooooooo! Hopefully they will fix my erratic gearknob too that keeps flying off into the passenger seat!!
  1. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  2. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  3. Replies: 5
    Last Post: 21st March 2010, 12:34
  4. Towbar removal suspension issue
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 21:41
  5. Facelift Suspension Issue.....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2006, 13:04
