Results 1 to 10 of 28
Thread: Diesel Vectra, Petrol Damage?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Diesel Vectra, Petrol Damage?
    Hi all,
    I've just bought privately a 2.2DTi that stopped working two weeks later, when my mechanic stripped the fuel pump he found PETROL in there, so obviously someone's filled it up (NOT ME I might add) and not had it cleaned out properly
    After the pump, tank and fuel lines being cleaned out properly, and the injector seals being replaced, it's packed up again, turning over fine but not firing.
    First impressions have been I might need a new engine , but can anyone tell me exactly HOW putting petrol in these diesel engines actually damages it? I'm hoping it's just the fuel pump that's gone, but knowing my luck it won't be ...
    I imagine it's to do with the way they work mate - diesels work on the compression of the air in the cylinder igniting the fuel, whereas petrolos have a lower compression and use a spark to ignite the mixture. With no way of igniting the fuel if you put petrol into a diesel engine, it'll just go through it without burning properly, if at all...
    Regular Member Readster's Avatar
    Plymouth
    Petrol ruins the fuel pump seals.
    Only if don't start the motor after filling with a diesel with petrol can you getaway with it.
    Have a specialist test the fuel pump for you before anything else.
    If it is damaged then a recon fuel pump will be available,or try a used unit with a guarantee.
    Hope this helps..
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Also a diesel pump uses the fuel as a lubricant,petrol doesn't lubricate as well as diesel causing wear.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Readster View Post
    Hope this helps..
    Thanks chaps - so if run with petrol in (which this obviously has been) does it just knacker the pump? Why has my mechanic over the phone suggested worse case a whole new engine (he's definately NOT the type to rip people off btw)? Would it damage valve seats or rings for instance? In the two weeks I've had it it only gave a puff of white smoke on start up, but otherwise nothing.
    Regular Member gromit's Avatar
    Cumbernauld
    I used to have 8 diesel vans on the go and there was always one idiot every now and again who would fill it with petrol. I can honestly say that none of them suffered and long term damage as a result. I think it happened four times (twice with the same guy) and they all drove them until the spluttered to a stop. I had the tank drained and filled with diesel and they all ran fine after that. The vans that happened to where a VXcombo, Transit Connect and a Peugot.
    I would think the damage would be limited to just the seals in the pump and injectors as the rest is basically the same as a petrol engine. Might be wrong though.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    I would shop around if you need a new fuel pump as the Dti engines have a rather expensive pump, IIRC its 4 figures. Whereas the newer common rail engines need not have a one so compicated. Just shop around as prices can vary.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by steve View Post
    FOUR FIGURES??? All I can think of is FOUR LETTERS right now!!!!
    Plymouth
    There are breakers on line that guarantee parts, if you have the fiat motor that may widen your choice.
    A lot of garages maintain that the motor is 'wrecked' but, I agree with gromit about the pump seals.
    The cheapest way out is a used fuel pump and consider selling the car on if you have any lingering doubts.
    Let us know how you get on
    Plymouth
    'First Choice' spares have diesel pumps
  1. Swap petrol to diesel, Vectra to Signum, Elegance to Elite
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2012, 20:26
  2. Help!!! Petrol in Diesel vectra
    By ectraz in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 16:37
  3. Buying a Vectra: Petrol or Diesel?
    By L11Marc in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 18:48
  4. Buying a Vectra: Petrol or Diesel?
    Last Post: 13th July 2008, 15:37
  5. damage to car BY B.P PETROL STATION
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2007, 22:06
