Results 1 to 10 of 11
Thread: Rear light cluster
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Rear light cluster
    Tried searching for this with no luck.
    Does anyone know what the second light down from the top is used for. (Brake light).
    What wattage is it as well, many thanks.
    Regular Member mishima's Avatar
    UK
    Are we talking about a Vectra C here? The top two lights are usually when your headlights are on. I replaced a bulb in mine last night that went, it was 21W!
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    all the bulbs in a vectra c rear lamp are 21 watt,dont put a lower wattage bulb in
    Regular Member badback's Avatar
    Runcorn
    Both are tail lights and the top one goes alot brighter when brake pressed. As above 21w.
    Mar 2007
    NI
    Thanks Lad's.... when I got the cluster out I saw the wattage... hard to get those bulbs as well, the fitting is only for the vec and a mondeo..... Sorted now...
    Tell me has anyone any hints in getting the off-side (passenger) cluster out... the 2 inner screws are a nightmare to losen, not much space to play with.
    Runcorn
    There's 3 small nuts holding the cluster on, the top one is the hardest to get at. Once they were off i only hand tighten the top one, because mine are on and off quite often.
    Regular Member scottyd's Avatar
    paisley
    is it not a 5w21w for one of the tail lights?
    Runcorn
    Both are single element bulbs, well they are on mine anyway.
    paisley
    ive never had too look
    Runcorn
    I'm in there regularly messing about with my tinted lights.
  1. Rear light cluster
    By KSD in forum Styling
    Last Post: 3rd February 2008, 15:26
  2. Rear Light cluster
    By phildews in forum Styling
    Last Post: 25th July 2007, 03:32
  3. Rear Light Cluster
    By Neil in forum Bodywork & Interior
    Last Post: 16th February 2007, 08:15
