Thread: auto headlights, fog lights and levelling system not working
    Apr 2009
    Derby
    Default auto headlights, fog lights and levelling system not working
    Hi,
    I'm new here as a new owner of a 1.9 CDTI 150 Design hatch and so far pleased with it. I have an odd problem that I thought I would ask about here first before going back to dealer i bought it from (non vx, I'm 3rd owner)
    The basic issue is that the headlights stay on all the time. Main beam works but the control knob doesn't affect the lights at all. They are auto on this model and at first I wondered if it had been specced for daytime running lights (06 plate) but when I realised that both front and rear fog lights, levelling adjuster and dashboard illumination control don't work I figured something else was amiss... I've also notice that the central panel (radio/climate) controls don't light up all the time - they do when you unlock and put key in but as soon as ignition is on they go out - a tad inconvenient at night.
    Before I go back to the dealer anything I should try? I thought a fuse might be missing/faulty but haven't come up with anything so far. Had a bit of a search round the forum but no luck there either!
    Cheers,
    Jon.
    Apr 2009
    Derby
    bump?
    Sunny Dartmoor
    I'd remove the switch an re-fit it,could be a bad connection,if not it'll probably be the switch,hth.........
    Apr 2009
    Derby
    Cheer glenboy - any hints on how - I can see 2 very small indents below panel which I guess should allow me to lever it off but not sure how - is this right before I bust something?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    iirc to remove the s/w unit, you have to push and turn the knob to poss 1 and it just pull's out.....
    hth
    Midlands Mod Shop - NFFC.
    Sunny Dartmoor
    Push in Headlight switch and move to position 1 it should pop out,i'm sure thats right...........
    Apr 2009
    Derby
    Position 1 being the far left (anticlockwise)? sorry being dumb.
    I'll go and try it when the missus gets home and let you know.
    cheers guys,
    Trim : Get a
    possition 1 being side light's on from left to right clockwise...
    Apr 2009
    Derby
    right - thanks. Cheers guys - your quick and helpful!
    Apr 2009
    Derby
    Ok.. had a crack at this tonight and got it fixed....
    Not very straightforward though! I tried push and position 1 thing and the whole panel goes in by about 3/4 inch but no further. I jiggled it about loads but it wasnt coming out.
    So, I removed the facia trim panel inbetween the vent and the panel and took out the vent with the 2 torx screw - I could then access the rear with the multi-pin. I thought I would try re-plugging the connector in situ but I couldn't figure out the clip (being a bit new at vec c's!)
    In the end I moved the whole bottom dash panel but this isn't actually possible since there is a single torx screw in a recess above the light control panel! After I had been jiggling it about a lot I actually ended up cracking the (very thin and flimsy) bit of dash this goes into which is a shame. I think I'm going to glue it up tomorrow to see if I can make it good as that part of the panel moves a little now!
    So, what was i doing wrong??? Even with the lower dash panel off and the multipin removed I couldn't figure out the module slots out!
    Anyway, the good news is it's fixed and the switches all work again!
    I might take some pics tomorrow to show how it comes out when I try and repair my handiwork!!
    Thanks,
    J
  1. One other thing... Auto levelling headlights
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2012, 12:09
  2. auto lights and wipers not working
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2011, 22:07
  3. GSI AFL self levelling headlights - fault
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2010, 14:19
  4. new springs and auto levelling headlights
    By animal22 in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2009, 19:50
  5. Xenon Headlights Auto Levelling Issue
    By bigstevex in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 21:14
automotive fog lights levelling
