Results 1 to 10 of 16
Thread: Can you repair a hole...
    Northampton, UK
    Default Can you repair a hole...
    Is it possible to repair a hole in a bumper? I'm talking about a hole, say the size of a parking sensor LOL. Just had an email from a friend back home who's tried to fit his own parking sensors. I wont mention what he drives, but I'm pretty sure the bumpers are the same sort of material, colour coded etc as our lot.
    He's put the sensors too low in the bumper, and they just go off full stop, no use at all! His bumper angles down so he cant aim the sensors to offset this. So it looks like he'll have to try and get the holes filled.
    But, firstly, is this possible??? Can you realistically fill a hole like that in a bumper? Would it be a solid repair (Assuming that the person doing the job was a top quality guy) etc, unlikey to crack etc?
    Regular Member jillydabrat's Avatar
    Apr 2009
    Teesside
    "Can you repair a hole"
    Wish someone would repair my hubbies, the backfire is killing me
    Full Member gibbon7000's Avatar
    lincs
    I'm sure you can, it would require plates been put behind the bumper covering the holes and then filled with the appropiate filler on the outside, then sprayed up.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Northampton, UK
    Quote Originally Posted by gibbon7000 View Post
    Hard/expensive job???
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    you ould also give plastic welding a go. get some donor bits of bumper from a scrapyard
    cut bits out the shape of the hole
    then just "solder" them in with more bits. need a very hot implement tho. they u can just sand it down and put a light covering of finishing filler on it and paint
    Regular Member Zark's Avatar
    Herts
    i'd use a few of these
    lincs
    Quote Originally Posted by n_hudson View Post
    I would say quite easy to do. having the bumper sprayed is gonna be the expensive bit
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    most places charge about 100 pound to paint a bumper so might be best to try and get a new bumper for that car in the orig colour depending what car it is ect, ebay is always a good start
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i have done a simalar thing, i used a soldering iron on the crack then a skim of filler
    llantwit major
    think he is on about holes the size of parking sensors not a crack or am i wrong, norm with cracks ona bumber your best to drill a hole at the end of the crack to stop the stress makin the crack continuing then smooth over with filler, or use some fiberglass at the back of it to make a back plate then fill and prime as per, to me seems a lot of messing about for four holes, sure you could pick a bumper up cheap of ebay, what car is this bumper problem on
  1. Big hole cut into my airbox
    By justin32 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th September 2011, 20:59
  2. So I have a hole in my AC condenser!
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 12:34
  3. A BIG hole
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 15th May 2009, 11:07
