Results 1 to 10 of 11
Thread: Fun in the garage & tyres
    Regular Member Readster's Avatar
    Plymouth
    Default Fun in the garage & tyres
    Armed with Vectra-C.com 'how too's', Haynes ,caliper rewind tool and my new torx socket set I advanced on my unsuspecting Vectra to change the rear discs & pads.
    All went good, although I'd like to see the handbrake with a bit more bite...perhaps it will when the pads have bedded in ( and yes I did clean the new discs)
    I changed the pollen filter, which was full of debris, the air filter (ditto) and did the airbox mod. It seems odd that VX would design a airbox that used only half the element...
    I noticed that the rear tyres are getting near my limit of 2mm so, I was wondering which tyres people have found to be a good mix of grip and wear.
    I have Bridgestone Turanza ER30's on there at the moment. 215/55R16 93H.
    A Plymouth tyre place has recommended Avon ZB5's as they are cheaper.
    Any thoughts ?
    I have a 1.9 estate btw.
    Next week, it's new front discs & pads,oil change and the dreaded fuel filter...
    John
    Surrey
    Move up to 225 width for more choice and cheaper.
    Hope you also checked the drain just in front of the pollen filter while you were at it John if not do so asap or pay the consequences .............
    Quote Originally Posted by steve1975l View Post
    He's not running 215/50/17's!
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Sorry to but can I do my front disks and pad without a rewind tool?
    Thanks Steve
    Blantyre
    Quote Originally Posted by vectra 120 View Post
    Thanks Steve
    Yes mate, dont need a rewind tool for the fronts
    Quote Originally Posted by spennny View Post
    Thanks m8
    Steve
    Plymouth
    Can you up a tyre size?
    Plymouth
    On the subject of re-winders, I was suprised at the effort it to get the caliper pistons back to fit over the new pads / discs. £20 wells spent.
    I needed to buy a new torque wrench for the front caliper bolts. Super tight Nm 230.
    I did think about just FT but it is brakes....
    Quote Originally Posted by Readster View Post
    Yes but keep the aspect ratio the same or close or it will put your speedo out
  2. New look garage
    By signumboy in forum General Chat
    Last Post: 1st October 2010, 22:09
  3. garage!!!!!!
    By mr f in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 09:13
