Results 1 to 10 of 17
Thread: Anyone Have Any Idea?
    Regular Member Bethan39's Avatar
    South Wales
    Default Anyone Have Any Idea?
    Just got in my car started fine a couple of minutes later i noticed that i have no fuel gauge speedo rev counter or temp gauge the car runs fine i can hear the indicators working brake lights all fine wipers radio all fine as far as i can tell it's only the instruments that are dead does anyone have any ideas? thanks in advance
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    fuse?
    South Wales
    Thanks mate any idea which one?
    Thumbs up
    not off the top of my head mate, if i get time tonite, ill have a look.
    or someone will be along later with the answer im sure.
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by Bethan39 View Post
    Looking on the manual it says the following fuse box inside the car fuse number 26= instruments/information display hope that help and right
    Steve
    also 7.5A
    Surrey
    Then try the connector at the back of the cluster.
    Any good m8
    Regular Member dlm71's Avatar
    Cheshire
    Don't wish to alarm you but the same happened to me approx 2 years ago, I thought it was a fuse but it turned out that a wire had rubbed against some metal behind the dash and shorted out! It was done under warranty but it was a big job, so I was led to believe
    Hope yours turns out to be the fuse!!
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    any luck with dash mate
    Ashington, Northumberland
    Sounds like the old chestnut of a duff CIM module. Or clean the ABS plug
  1. anyone got an idea?
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 17:17
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
